By buying this product you get 32 loyalty points
Module Amplificateur Stéréo / Mono Class D 2x230W 4Ω / 1x500W 8Ω
The ICEpower 250ASX2 is a compact Class D amplifier module that can operate in both stereo and mono. It is thus capable of delivering a power of 2x230W under 4Ω or 1x500W under 8Ω, while ensuring a precise and detailed sound reproduction. It also has its own power supply stage for a minimum footprint, ease of integration and, above all, top performance. Its ±24VDC auxiliary power supply output, which can be used to power external modules, as well as the elimination of any heat sink or EMI shielding, makes the module even easier to implement. It also benefits from a series of protections against short-circuits, overloads and overheating.
Product type | Amplifier board |
Amplification ty^pe | Class D |
Channels | Stereo (2) / Mono (1) |
Input | 1* Analog input on JST 8 pins connector |
Output | Speaker output on JST 4 pins connector |
Output power @ SE, THD+N 1%, 20Hz-20kHz | 2x230W @ 4Ω, 230VAC 2x200W @ 4Ω, 115VAC |
Output power @ BTL, THD+N 1%, 20Hz-20kHz | 1x500W @ 8Ω, 230VAC 1x420W @ 8Ω, 115VAC |
Minimum load impedance | 3Ω |
Maximum total amp + PSU efficiency | 81% |
Peak output current | 20A |
Dynamic range | 125dB |
Output noise @ A-Weighted | 20µV |
THD+N (1W/1kHz) | 0.002% |
Supply voltage | 85-264VAC (supply voltage switchable via jumper) (power supply not included) |
Dimensions | 210*80*35mm |
Package | 1* ICEpower 250ASX2 Wiring cables |
Input | PCB Connector |
Output | PCB Connector |
Channel | 2 (Stereo) |
Channel | 1 (Mono) |
Class | Class D / T |
Amplifier chip | N/A |
Power (W) | 230.0 |
Power (W) | 500.0 |
