IRS2092 Stereo Class D Amplifier module 2x 400W 4 ohm
10%
Ce module amplificateur stéréo est idéal pour tout amateur désirant un son de qualité Haute Fidelité avec une bonne puissance sans les défauts de la classeD habituelle. Il sera assez facile à mettre en oeuvre avec une alimentation SMPS 800 Re +/-60V.
Reduced price!
Reference : 9760
Limited time offer:
139,00 €tax incl.
-10%
125,10 €tax incl.
104,25 € tax excl.
Shipping date: 26-06-2025.
This Class D amplifier module is based on the IRS2092S amplifier controller and Hexfet Fairchild and IRF transistors. It is designed for any enthusiast looking for power and high fidelity to deliver a robust and melodic sound with a high level of bass resolution. This amplifier has some refinements, especially in its output filter, which is a determining part in the sound result. The output chokes are from Koo-Mu Magnetics and Sagami of audiophile quality.
It requires a cooling fan unlike the lower power IRS2092 modules.
To operate, this module in its 400W version requires a power supply between +/- 60V and +/- 66V.
Connex Electronics and Audiophonics recommend the  SMPS 800 RE  +/- 60v power supply, designed for this module. See the connection diagram at the bottom of the page or the PDF.
If a Connex power supply recommended by the manufacturer is not used to power the module, then the module will require, in addition to the +/-VCC power supply, additional +AUX, -AUX and Vbias power supplies to be distributed on the AuxSupply connector.
Characteristics of the IRS2092 amplifier:
  • Controller IRS2092S
  • Fairchild and IRF transistors
  • High quality chokes KOO Mu Magnetics and Sagami
  • Protection against short circuits and overloading
  • Dimensions : 100x100x42mm
  • Output power : 400W under 4ohms or 200W under 8ohms
  • Female connector and output on flexible wire delivered
All connection information is shown in the Builder and drawings PDF and SMPS power supply.
IRS2092
https://www.audiophonics.fr/images2/6945/6945_IRS2092_2.jpg
InputNC
OutputScrew terminals
Channel2 (Stereo)
Amplifier chipInfineon IRS2092
Power (W)400.0
2 reviews
Connex IRS 2092 2x400W
Preislich gesehen ein sehr guter Verstärker. Toller Auflösung im Hochton und Mitteltonbereich.
Leistungsmässig eine Macht.
Angeschlossen an einem Hypex SMPS 1200 A400
Anschliessen ist selbsterklärend. Alles wunderbar beschriftet.
This review has been posted for IRS2092 Stereo Class D Amplifier module 2x 400W 4 ohm
Bon ampli sur HPs à pas trop grande sensibilité (souffle audible sinon)
Cet ampli est très bien, mais comme tous les ampli classe D, attention toutefois à ne pas l'utiliser avec des HPs trop sensibles (
Ce module amplificateur stéréo est idéal pour tout amateur désirant un son de qualité Haute...
