LJM L15 Mono Amplifier Modules (Pair)
LJM's L15 is a dual mono amplifier module kit, each delivering 150W under 8Ω. These are based on 3 IRFP240 MOSFETs and 3 IRFP9240 MOSFETs used in a Class AB architecture. These modules support power supplies ranging from ±15V to ±70V. Each of the two modules is delivered attached to an aluminium plate, ready to be fixed within an enclosure.
Reference : 19971
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 13-05-2026.
LJM L15 Mono Amplifier Modules 150W 8Ω (Pair)
LJM L15 : Front view
LJM L15: PCB diagram
LJM L15 : Test de réponse en fréquence
LJM L15 : Mesures THD+N
LJM L15 : Spectre FFT
Product typePower amplifier modules
Power transistors3x IRFP240
3x IRFP9240
Output power150W @ 8Ω±55VDC
300W @ 4Ω±55VDC
600W @ 2Ω±55VDC
ArchitectureClass AB
Frequency response10Hz - 30kHz (-0.05dB)
Total harmonic distortion (THD)0.02 % @ 150W, 8Ω
SNR> 97dB
Voltage gain31x
Input1x Screw terminal
Output1x Solder pads
Power supply voltage±15V - ±70V DC
DimensionsPCB : 40 x 150mm
PCB + Aluminium plate : 74 x 150mm
Spacing holes138.5 x 28.5mm
Weight350g
Package2x LJM L15
InputScrew terminals
OutputSolder pad
ChannelDual Mono
ClassClass A / AB
Amplifier chipTransistors
Power (W)150.0
LJM L15 Mono Amplifier Modules 150W 8 Ohm (Pair)
LJM's L15 is a dual mono amplifier module kit, each delivering 150W under 8Ω. These are based on 3 IRFP240 MOSFETs and 3 IRFP9240...
