TINYSINE TSA7551B Mono Amplifier TDA7498E DSP ADAU1701 Bluetooth 5.0 TWS aptX 170W 3 Ohm
The TinySine TSA7551B is a mono amplifier module featuring Bluetooth 5.1 connectivity and DSP. Its high-efficiency amplifier stage, based on a TDA7498E chip, delivers 170W into 3Ω (36V, THD=1%).
Reference : 18393
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 04-07-2025.
TinySine TSA7551B
Tinysine TSA7551B Amplificateur Mono TDA7498E DSP ADAU1701 Bluetooth 5.0 aptX 170W 3 Ohm
The TinySine TSA7551B is a mono amplifier module featuring Bluetooth 5.1 connectivity and DSP. Its high-efficiency amplifier stage, based on a TDA7498E chip, delivers approx. 170W into 3Ω (36V, THD=1%). Bluetooth reception is entrusted to an AudioB Plus module supporting the high-resolution aptX codec for quality wireless sound reproduction. The TWS function is also supported, enabling two modules to be linked together to broadcast an audio stream simultaneously to them.
The module's DSP management uses an ADAU1701 chip. Whether Bluetooth or 3.5mm stereo input, left and right channels are mixed by DSP. The DSP can also be used to adjust gain, bass, midrange and treble levels, and a debug port for Sigma Studio is also available. The module can be programmed using the USBi Tinysine programmer (sold separately) to access a wide range of functions such as equalization, crossover, bass enhancement, multiband dynamic processing, delay compensation, etc.
The TinySine TSA7551B module features an intelligent cooling system with a fan that operates only when the board is overheated, to limit noise. The module can be powered over a wide voltage range, from 14V to 39V DC.
1External LED connector
2 / 3DC power supply inputs
4Jack 3.5mm input
5DSP input / output
6External control panel connector
7Potentiometer connector
8DSP programming port
9Audio output (spk out)
10Audio output (analog out)
11MUTE connector
12Bluetooth Audio B Plus receiver module
13ADAU1701
Module operation
Connector for external control panel :
The module features 3 buttons for volume and playback control. External buttons can also be connected using the dedicated control port.
Pinout (refer to silkscreen on back of card) :
  • P/P: Play/pause button
  • VOL+: Volume up and fast forward button
  • VOL-: Volume-down and fast-return button
  • 1.8V
Tinysine TSA7551B Amplificateur Mono TDA7498E DSP ADAU1701 Bluetooth 5.0 aptX 170W 4 Ohm
Potentiometer connector :
The module also incorporates a connector for external potentiometers (5k ~ 20k) to control volume, agius, midrange and bass. To do this, the DSP program must first be updated. TinySine offers a 4-potentiometer kit (sold separately) for this purpose.
  1. ADC0: Main volume
  2. ADC1: Bass volume
  3. ADC2: Midrange volume
  4. ADC3: Treble volume
DSP programming port :
You can load a new DSP program using TinySine's USBi JTAG DSP programmer (sold separately).
Operation of two modules in TWS :
You can combine two TWS modules to create a stereo wireless audio system.
Tinysine TSA7551B Amplificateur Mono TDA7498E DSP ADAU1701 Bluetooth 5.0 aptX 170W 4 Ohm Tinysine TSA7551B Amplificateur Mono TDA7498E DSP ADAU1701 Bluetooth 5.0 aptX 170W 4 Ohm
  • S1: Long press for 3s to activate pairing. Long press for 6s to reset pairing.
  • S1+S2: Long press 1s to activate TWS slave mode.
  • S1+S3: Long press 1s to activate TWS master mode.
  • S2+S3: Long press 1s to deactivate TWS connection.
Product typeAmplifier module
Amplification typeClass D
Amplifiction chipTDA7498E
Channels1 (mono)
InputsBluetooth 5.1
1x Jack 3.5mm
OutputSpeaker terminals (screw terminal)
Output power220W @ 3Ω, 36V, THD 10%
170W @ 3Ω, 36V, THD 1%
DSP chipADAU1701
THD0.05% @ 1W
Frequency response @ ±3dB20Hz-20kHz @ 4Ω
Input impedance69kΩ
ProtectionsOvervoltage
Undervoltage
Overload
Overheating
Undervoltage protection threshold8V
Minimum load impedance3Ω
GainMin: 23.8dB
Typ: 29.8dB / 33.3dB
Max: 35.8dB
Efficiency85%
Suported Bluetooth codecsSBC, AAC, aptX, aptX LL
Supply voltage14-39VDC
Dimensions135*92*35mm
InputJack 3.5mm
Channel1 (Mono)
Amplifier chipTDA7498E
Power (W)170.0
The TinySine TSA7551B is a mono amplifier module featuring Bluetooth 5.1 connectivity and DSP. Its high-efficiency amplifier stage, based on a...
