TINYSINE TSA8804 V2 Amplifier Module TDA7498E Bluetooth 5.1 DSP 4x100W 4 Ohm
The TinySine TSA8804 is a 4x100W Class D amplifier module based on a TDA7498E chip. It can be powered over a wide voltage range of 14V to 39VDC and can be used to drive 4Ω or 8Ω speakers. It also integrates a Bluetooth 5.1 receiver. This makes it possible to stream music remotely from a smartphone or tablet, for example.
Reference : 17304
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 10-06-2025.
TinySine TSA8804 v2
Module amplificateur TDA7498E Bluetooth 5.1 DSP 4x100W 4Ω
TinySine TSA8804 Module amplificateur TDA7498E Bluetooth 5.1 DSP 4x100W 4Ω
The TinySine TSA8804 is a 4x100W Class D amplifier module based on a TDA7498E chip. It can be powered over a wide voltage range of 14V to 39VDC and can be used to drive 4Ω or 8Ω speakers. It also integrates a Bluetooth 5.1 receiver. This makes it possible to stream music remotely from a smartphone or tablet, for example. This function can also be used to associate several TSA8804 modules together. It is thus possible to set up a real wireless surround sound system using several modules.
1DC power input on screw terminals
2DC power input on Jack DC connector
3Output bridge enable A
4Gain settings
5Jack 3.5mm input
6Bluetooth antenna U.FL connector
7Bluetooth programming port
8External buttons and LEDs port
9Pairing buttons
10Speaker outputs
11DSP programming port
12Potentiometers port
13Output bridge enable B
14Gain settings
TinySine TSA8804 board operation
Pairing buttons:
  • PAIR : Double click to enter into pairing mode
  • TX : Click to activate transmitter mode
  • RX : Click to activate receiver mode
Use of a single module as an amplifier and Bluetooth receiver
Use of several modules associated together
Operation guide:
Master board:
  1. Power supply the TSA8804 module. A blue LED flashes slowly.
  2. Press the PAIR button twice to enter pairing mode. The blue LED flashes rapidly.
  3. Now connect your smartphone to the module via Bluetooth. The module is identified by the name TSA8804.
  4. You can now play your music. If you use only one module, the following steps are not necessary. These steps allow the use of several modules in combination.
  5. Press the TX button to activate the transmitter mode on the module. A red LED lights up.
Slave board:
  1. Power supply another TSA8804 module. A blue LED flashes slowly.
  2. Make sure the master module is functioning properly and is in transmitter mode. Press the RX button to activate the receiver mode on the slave module. The slave module will then automatically search for the master module. A green LED lights up.
  3. Press the RX button on the slave module twice and the TX button on the master module twice. The master module automatically searches (30s) for the slave module. The master and slave modules are now connected.
  4. The slave module can now play sound.
  5. If you want to add other slave modules, simply repeat the previous steps on them.
  6. To disassociate a slave module, press its TX button.
Activation of the bridge mode :
The TSA8804 is based on the TDA7498E chip. It can therefore be used in stereo or mono BTL. For this, you can use a jumper to close the contacts corresponding to the bridge mode of the module. It is then necessary to connect SPK1+ and SPK2+ together and do the same for SPK1- and SPK2-. It is possible to perform this operation on SPK3 and SPK4 in the same way.
Product typeAmplifier board
EntréesBluetooth 5.1
1* Jack 3.5mm
SortiesSpeaker outputs
Supported Bluetooth technologiesQualcomm cVc
Qualcomm TrueWireless
Output power125W @ 36VDC, 1% THD
160W @ 36VDC, 10%THD
BTL Output power (mono)170W @ 36VDC, 3Ω, 1% THD
220W à 36VDC, 3Ω, 1% THD
Efficiency85%
THD0.05% @ 1W
Gain23.6dB @ Gain < 0.25*VDD
29.6dB @ 0.25*VDD < Gain < 0.5*VDD
33.1dB à 0.5*VDD < Gain < 0.75*VDD
35.6dB @ Gain > 0.75*VDD
Minimum load4Ω
Operating temperature range0-50°C
Supply voltage14-39VDC
Dimensions143*110*20mm
InputJack 3.5mm
OutputSpeaker terminal
Channel4
Amplifier chipTDA7498E
Power (W)100.0
The TinySine TSA8804 is a 4x100W Class D amplifier module based on a TDA7498E chip. It can be powered over a wide voltage range of 14V to 39VDC and...
