WONDOM AA-AB32256 Amplifier Module FDA TAS5754 2x30W 4 Ohm 24bit 192kHz
The Wondom AA-AB32256 module is a high-performance Class D amplifier with an integrated audio processor. It is based on an amplifier chip TI TAS5754, allowing it to develop a power of 2x30W under 4Ω (THD 10%) with a high efficiency.
Reference : 14771
35,90 €tax incl.
29,92 € tax excl.
Wondom AA-AB32256
Wondom AA-AB32256 Module Amplificateur Class D TAS5754 2x30W 4Ω 24bit 192kHz
The Wondom AA-AB32256 module is a high-performance FDA amplifier with an integrated audio processor. It is based on an amplifier chip TI TAS5754, allowing it to develop a power of 2x30W under 4Ω (THD 10%) with a high efficiency. The AA-AB32256 has an I2S input and supports file playback up to 24bit 192kHz, allowing you to enjoy your music in high quality. Its smart design ensures low noise, high SNR and THD+N of only 0.6%. In addition to the speaker output on terminals, the module offers a DAC output that does not pass through the amplifier stage, as well as an amplified analog output on PH2.0 connectors. Finally, the module can be associated with an ON/OFF button and a volume control (sold separately).
Product typeAmplification module
InputsI2S
Digital 3 pins
OutputSpeaker terminals
DAC output without amplification
Analog output with amplification
Amplification chipTAS5754
Power2x 30W @ 4Ω, 19VDC, THD+N 10%
Supported sampling ratesUp to 24bit 192kHz
Measurements
ParameterConditionsMinTypMax
Power supplyJ2/J4 (Power adapter/Power supply)10VDC19VDC24VDC
J3 (Battery module)14VDC-21VDC
Max. current30W @ 4Ω-3A-
Efficiency30W @ 4Ω-90%-
Min. load impedance--4Ω-
Switching frequencySD floating, 8 x Fs, LRCK = 48kHz-384kHz-
GainCan be adjusted up to -100dB with the Wondom Volume Control Module-28dB-
Power@ 4Ω, THD+N 10%-30W-
Frequency response@ ±3dB, 4Ω20Hz-20kHz
THD@ 4Ω, 1W, 1kHz-0.05%-
Output noise levelA-Weighting-80µV-
SNRTHD+N < 1%, A-Weighting-102dB-
Dimensions91.4 x 68.6mm
Weight58g
Wondom AA-AB32256 Module Amplificateur Class D TAS5754 2x30W 4Ω 24bit 192kHz Wondom AA-AB32256 Module Amplificateur Class D TAS5754 2x30W 4Ω 24bit 192kHz Wondom AA-AB32256 Module Amplificateur Class D TAS5754 2x30W 4Ω 24bit 192kHz Wondom AA-AB32256 Module Amplificateur Class D TAS5754 2x30W 4Ω 24bit 192kHz
InputI2S
OutputPH 2.0mm
Channel2 (Stereo)
Amplifier chipTAS5754
Power (W)30.0
The Wondom AA-AB32256 module is a high-performance Class D amplifier with an integrated audio processor. It is based on an amplifier chip TI...
