Max sampling rate
DAC / ADC Chip
Amplifier chip
Class
Power (W)
2 - 1000
Channel
Input
Output
Remote Control
Streaming services
Color
Rémi D.
N'hésitez pas
Antony C.
Best rapport Qualité/Prix !
Laurent C.
Une référence
Audio amplifiers
HiFi systems require audio amplifiers. Here you'll find all our high-fidelity amplifiers, which will enhance your sound and bring out the best in your speakers. From power amplifiers to integrated amplifiers, all powers and all classes (A, D, T) are available to meet your needs.
Each amplifier is made up of an amplification module, an internal power supply, capacitors, printed circuits and a host of other components. You can be sure of the quality of these components in the amplifiers we offer.
  • Integrated amplifiers
    Here you'll find our selection of high-fidelity integrated amplifiers. Unlike power amplifiers, these have a pre-amplification section, notably via a volume knob and/or a source selector. Whether Mono or Stereo, you can plug your HiFi speakers directly into them and enjoy their impeccable sound.
  • Connected amplifiers
    Explore our selection of connected amplifiers. Connected amplifiers are mostly stand-alone devices, meaning they often combine the functions of network players and amplifiers. One of the most evocative terms for this category of Hi-Fi devices is the famous Just Add Speakers, which explicitly defines the concept. Simply add speakers to a connected amplifier and enjoy your favorite music sources.
  • Power amplifiers
    Power amplifiers
    In this category you'll find our selection of Power Amplifiers. Unlike integrated amplifiers, these only add power to the signal received, so they don't have built-in pre-amplification to concentrate on the very essence of amplification. Whether it's a Mono Power Amplifier or a Stereo Power Amplifier, find the ideal solution to perfect your HiFi installation.
  • Audiophonics Workshop Amplifiers
    All the amplifier models in this catalog are directly assembled in our Workshop located in Bordeaux. We selected the highest performing amplification circuit (Hypex NCORE, Purifi) to make the most from the best amplification technologies while maintaining an unrivaled budget on the high-end amplifier market. Available as mono blocks or stereo combined to meet all your integration constraints.
    Discover our full range of amplifiers made in France on our blog : Discover our range of Audiophonics Workshop amplifiers.
  • Ref : 11845
    In Stock
    Wondom proposes here a TA2024 Clas D amplifier delivering a power of 2x15W under 4Ω, ideal for any secondary or auxiliary HiFi installation. Thanks to its compact design, its elegant case and its great ease of use, this amplifier will allow you to listen to your favorite songs on your audio systems with extreme simplicity.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 16546
    In Stock
    The xDuoo DA-100, although compact and affordable, is very versatile, taking on the functions of Class D amplifier, headphone amplifier and DAC. Its careful design embeds a TPA3116 amplifier allowing it to develop a 2x50W power, a MAX97220 headphone amplifier and a ES9018K2M DAC ensuring low distortion and high SNR. A 1.3" OLED screen displays information...
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 16835
    In Stock
    The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a TI TPA3116 chip, allowing to deliver a 2x30W power output under 4Ω with a high efficiency. However, the circuit also integrates a 12AU7 tube, allowing to enjoy the soft and...
    129,00 € 107,50 €Ex.
    In Stock
