MOONDROP PARA II Headphones
The Moondrop PARA II is a planar magnetic headphones featuring Full Drive Technology (FDT) and large 100mm-diameter diaphragms. The result is rich, precise and dynamic sound reproduction, combined with a wide soundstage for a refined, immersive listening experience. Particular care has been taken to ensure exceptional sound performance in a modern design.
Reference : 20981
494,91 €tax incl.
412,42 € tax excl.
Shipping date: 25-11-2026.
Moondrop PARA II Headphones Open-Back Planar Magnetic FDT Ø100mm 106dB 9Ω 20Hz-42kHz
Moondrop PARA II headphone
Key features on Moondrop PARA II
Moondrop PARA II loudspeaker
Moondrop PARA II: Large 100mm FDT membrane
Unlike traditional magnetic planar headphones, the PARA range adopts a very large 100mm diaphragm using Full Drive Technology (FDT). The entire vibrating surface of the diaphragm is uniformly covered with efficient circuitry and encapsulated in a magnetic field. This technology delivers far more effective vibrations than traditional planar magnetic headphones, and is comparable to electrostatic headphones.
Comparaison entre technologie planar magnetic classique et technologie Full Drive
Moondrop PARA II: N52 magnet array optimized by FEA
The Moondrop PARA II adopts an array of 36 wide neodymium N52 magnet strips to generate a planar magnetic field covering the entire vibrating surface. This design has been optimized using FEA simulation to ensure uniform and efficient magnetic field distribution.
Magnetic field distribution on the Moondrop PARA II membrane
Moondrop PARA II: An ultra-thin membrane
Moondrop PARA II headphones feature an ultra-thin diaphragm measuring just 1.2µm, enhancing detail and bass depth while optimizing speed of response. It also uses pure silver soft circuit etching technology, largely eliminating the influence of circuitry on membrane surface tension for perfectly distributed vibrations.
The PARA II also adopts TBT (Tension Balancing Technology) for improved surface tension balancing, improving the uniformity of vibrations across the diaphragm, maintaining low distortion and wide dynamic range.
Moondrop PARA II: Ultra-thin membrane
Moondrop PARA II: Robust, lightweight design
The Moondrop PARA II inherits the internal structure of the VENUS headset, while improving the shell design and materials. The internal structure of the PARA II promotes uniform distribution of the magnetic field over the diaphragm. What's more, after extensive mechanical simulation, the aluminum alloy frame of the VENUS was replaced by industrial-grade plastic capable of supporting the load of the magnetic circuit while significantly reducing the weight of the helmet.
Exploded view of the Moondrop PARA II Magnetic load distribution on the body of the Moondrop PARA II helmet
Moondrop PARA II: A broad, perfectly optimized response
Thanks to the use of advanced technologies and meticulous tuning by Moondrop's R&D team, the PARA II delivers both incredible acoustic performance and a refined listening experience.
With a high degree of correspondence to the VDSF target frequency response curve and a finer suspension system, the PARA II delivers an open, natural soundstage. Slight treble extension reveals detailed sound and rapid response for a natural timbre.
Even at pressure levels in excess of 1Pa, PARA II is capable of very low non-linear distortion, below 0.05% over virtually the entire frequency band.
Moondrop PARA II response curve Moondrop PARA II response curve
Moondrop PARA II: Universal and interchangeable 3.5mm double jack cable
The PARA II features 3.5mm jack connectors, ensuring compatibility with a wide range of cables. It also comes with a detachable cable with high-purity 6N copper conductors for perfect signal transmission. This cable is terminated in 4.4mm jack format.
Interchangeable cable for Moondrop PARA II headset
Moondrop PARA II: Comfortable pads
The PARA II pads are made from specially selected sheepskins, ensuring excellent wearing comfort and durability. They are designed to be easily removed and adjusted thanks to a magnetic fastener.
Moondrop PARA II helmet pads
Moondrop PARA II: Aluminum shells
The PARA range adopts an industrial aesthetic combining design and practicality. The shells of the Moondrop PARA II helmet are made of polished stainless steel, perfectly combining the clean lines of the Bahaus aesthetic with ultra-modern sobriety.
Moondrop PARA II aluminum shells
Product typeHeadphone
Headphone typeOpen-back
Circum-aural
TechnologyPlanar magnetic FDT
Impedance9Ω ±15% @ 1kHz
Sensitivity106dB/Vrms @ 1kHz
THD≤ 0.03% @ 1kHz, 94dB
Frequency response20Hz - 42kHz (IEC61094, Free field)
Effective frequency response20Hz - 20kHz (IEC60318-4, -3dB)
Headphone connectorsJack 3.5mm
Cable endBalanced Jack 4.4mm
Package1x Moondrop PARA II
Earpads
1x Jack 4.4mm cable
1x Jack 4.4mm to Jack 3.5mm adapter
ColorSilver
Impedance (Ω)9
Efficiency / Sensitivity (dB)106.0
Lowest frequency (Hz)20
Highest frequency (Hz)42000
WirelessNo
Cable terminationJack 4.4mm
Headphone / Earphone connectorJack 3.5mm
MOONDROP PARA II Headphones Open-Back Planar Magnetic FDT Ø100mm 106dB 9Ω 20Hz-42kHz
The Moondrop PARA II is a planar magnetic headphones featuring Full Drive Technology (FDT) and large 100mm-diameter diaphragms. The result is rich,...
