SMSL SA-160 Amplifier TDA7498E 2x 100W 4 Ohm / Headphone Amplifier Black
Reference : 9716
109,00 €tax incl.
90,83 € tax excl.
Here is a Class D amplifier architectured around a TDA7498E delivering 2x 100W, the SA-160 also incorporates a headphone amplifier capable of supplying 130mW under 32 Ohms.
It is designed from high-end components such as Elna capacitors, Nichicon, ALPS potentiometer, EPCOS filter, etc.
It is a powerful and robust amplifier whose entire chassis is made of Aluminum.
The design and finishes are neat (CNC machining), its ergonomics is an indisputable advantage.
Its technical characteristics are a significant advantage compared to the competitors of this range: it is efficient and precise.
Characteristics :
  • Amplifier TDA7498E
  • Frequency response: 20Hz - 20kHz to +/- 3dB
  • Noise Ratio: 98dB
  • THD: 0.01%
  • Output Power: 2x 100W Under 4 Ohms
  • Input Level: 400mV - 2V
  • Headphone output power: 130mW (under 32 Ohms)
  • THD = N: <0.009%
  • Adjusting volume
  • EMI Filtering
  • Short circuit protection
  • Protection against overheating
  • RCA Stereo Input
  • Headphones Jack 3.5mm
  • Output Hp terminal blocks accepting banana plugs
  • Chassis Anodized Aluminum Black
  • Dimensions: 168x98x36mm
  • Weight: 1.5kg
  • Black color
  • Power Supply 36V DC 5.7A included
[Img-10116-left-thickbox_default]
[Img-10117-left-thickbox_default]
[Img-10118-left-thickbox_default]
