LHY AUDIO OCK-2S Master Clock OCXO 10MHz Black
The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six independent 10MHz 50/75Ω outputs on BNC connectors, including three sine-wave and three square-wave outputs. Based on a high-performance OCXO oscillator, it significantly improves the performance of any Hi-Fi system.
By buying this product you get 109 loyalty points
Reference : 19892
1 099,00 €tax incl.
915,83 € tax excl.
Shipping date: 12-05-2026.
LHY AUDIO OCK-2S Horloge Maître OCXO 10MHz Noir
Photo de l'horloge LHY Audio OCK-2S
Inside, you'll find quality components, including a linear power supply delivering a clean, pure signal with EMI filter, Talema 15VA transformer and high-speed rectification filter. The crystal oscillator is powered by three LT3042 + PNP voltage regulators, guaranteeing a high level of precision.
Photo de l'intérieur de l'horloge LHY AUDIO OCK-2S
Overview of LHY-Audio OSK-2S
Aperçu du LHY-Audio OSK-2S
13x 10MHz 50/75Ω sine wave clock output on BNC connector
23x 10MHz 50/75Ω square wave clock output on BNC connector
3Power input / Fuse / Bouton de mise sous tension
Product typeMaster clock
OscillatorOCXO
Output waveform3x Sine wave
3x Square wave
Output frequency6x 10MHz
Output impedance50 ohm
75 ohm
Frequency stability< ±5ppB
Frequency precision< ±0.05ppm
Output noise≤ -110dBc @ 1Hz
Short term stability< ± 2x10-12 @ 1s
Heating time15min
ConsumptionPreheating: 8W
Working: 5W
Dimensions240 x 50 x 175mm
Weight2.1kg
Package1x LHY AUDIO OCK-2S OCXO 10MHz master clock
1x Schuko power cable
3 reviews
Great value for your listening pleasure!
The LHY OCK2-S synchronises the AGD DIS5HE and AGD R27HE in my system. I must say that, even though the quality of AGD devices is already very high, with the addition of this LHY clock, the leap forward has been very noticeable.
I am very satisfied with my purchase!
Obviously, as usual, Audiophonics is the best!!!
This review has been posted for LHY AUDIO OCK-2S Master Clock OCXO 10MHz Black
Very good
I used the Ock-2s in conjunction with a Singxer SU-2 to reclock a Topping D90iii via i2s. This combination clearly beats the Singxer SU-6 which does not have a clock input but also has a accurate clock built-in..
I was sceptical to try a master clock for listening purposes (as opposed to sound studios) but In my system it works very well.
This clock by LHY has converted me into an audio master clock believer. At least in my own systems I am never going to listen to digital audio again without a good clock in the chain.
It simply takes care of removing that last bit of digital edge/jitter/smear...whatever stuff of digital audio you don't want.
I do believe it requires a really revealing and neutral system to get the most out of it.
Génial !!!
Connectée sur mon streamer RS130 et Dac RD160 de chez Hifi Rose, le gain est significatif. J'utilise des câble coax Amphenol PMR400, c'est tellement mieux que certains câble plus chers que j'ai essayé. Si utilisation en mode sinusoïdale, je conseille de mettre des filtre pas bas BLP-10.7+ au niveau des équipements connectés, l'apport est incroyable.
 (3)
The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams....
