Connector
Impedance (Ω)
Max cable diameter (mm)
Rated current (A)
Connectic
Section (mm²)
0 mm - 50 mm
Contacts Material (Connector)
Contacts Plating (Connector)
Contacts number
1 - 19
Mounting type
Accepts Banana Plugs
Max panel thickness
mm
mm
Color
Insulation material
Laurent C.
Trés satisfait
Trés bon Kit bien réalisé, bien documenté fonctionne parfaitement avec un rendu impressionnant.
4/5 parce qu'on peut...
Baptiste B.
Je débute une installation hi-fi qui évoluera, il en est la première pièce.
Niveau puissance, c'est génial, je...
Jiří H.
Improving sound quality
Huge improvement in sound quality: detail, separation, spacing. The price/performance ratio is amazing.
Connectors
Whatever the intention and the desired result for your HiFi audio installation, find our complete range of connectors of all kinds: USB, DC Jack, DIN, XLR, RCA, Banana, Fork, Sector, Antenna / Sat / BNC, Toslink Optics, etc...
For all audio realizations or DIY assemblies, you will need high quality connectors to fully meet your expectations.
  • RCA Connectors
    RCA Connectors
    We offer a very wide range of RCA connectors. RCA plugs are essential in the audio industry, and are available depending on the material used, the plating applied, or the mode of use: crimp, solder, or clamp.
    Among our many RCA connectors, discover the well-known brands such as Furutech, Elecaudio, Neotech, or 1877PHONO. A large choice of high quality RCA plugs, in OCC copper or pure silver.
  • Jack Plugs
    Jack Plugs
    We offer a very wide range of Jack connectors. Jack plugs are essential in the audio world, and are available in different formats, materials, plating, or in different ways: crimping, soldering, or clamping. Among our numerous jack connectors, discover the recognized brands such as Furutech, Elecaudio, Neotech, or 1877PHONO.
  • Optical Toslink Plugs
    Discover our range of Optical Toslink connectors to design your own optical digital audio cables.
  • USB Connectors
    USB Connectors
    Discover our range of USB connectors, to design your own USB cables of all formats, for data transfer or audio.
  • XLR Plugs
    XLR Plugs
    Discover our wide range of male and female XLR connectors, for the design of your XLR or AES/EBU audio cables.
  • Power Plugs & Sockets
    Power Plugs & SocketsDiscover our wide range of power plugs, IEC, Schuko or other formats, to design your HiFi power cables.
  • DIN Plug
    DIN Plug
    Discover our range of DIN connectors and plugs, for the design of your cables and the integration of DIN connectors in your HiFi equipment.
  • Speakon Plugs
    Speakon Plugs
    Discover our range of Speakon connectors and plugs, a format mainly used in the world of professional audio and sound reinforcement.
  • RCA Sockets
    RCA Sockets
    Discover our range of RCA plugs, for the integration of an RCA connector in your HiFi devices or on your audio modules.
  • XLR Sockets
    XLR Sockets
    Discover our range of XLR plugs, for the integration of an XLR connector in your HiFi equipment or on your audio modules.
  • Jack DC Plugs
    Jack DC Plugs
    Discover our range of DC jack connectors and plugs, for the design of your power cables or the integration of power connectors in your HiFi devices.
  • Binding Posts & Terminals
    Discover our range of speaker terminals, alone or mounted on a plate, for the design of your speakers or HiFi amplifiers.
  • Banana Plugs
    Banana Plugs
    Banana PlugsDiscover our range of banana plugs, for the design of your speaker cables.
  • Spades
    Spades
    Discover our range of spade connectors, for the design of your speaker cables.
  • Antenna / Sat / BNC Plugs
    Discover our range of SAT, antenna and BNC connectors, for the design of your audio and video cables.
  • Crimp Sleeves
    Crimp Sleeves
    Discover our range of crimp connectors, in various diameters, to quickly and easily assemble your own HiFi audio cables.
  • Terminals
    Terminals
    Discover our range of cable lugs, in various sizes and formats, for the creation of your cables allowing fast and simple connections.
  • Plane type plugs
    Plane type plugs
    Discover our range of Aviation (GX) connectors for the design of your HiFi cables.
  • RJ45 Plugs
    RJ45 Plugs
    Discover our range of RJ45 connectors and plugs, for the design of your Ethernet network cables or the integration in your network and HiFi devices.
  • Various Plugs
    Various Plugs
    Discover our connectors with specific formats, for well-defined uses.
  • Connectors accessories
    Rings, crimps, markings, XLR connectors, RCA, bananas, forks, mains plugs.
