AUDIO-TECHNICA ATH-M50XBT2 Closed-Back Dynamic Headphone Bluetooth 5.0 Ø45mm 38Ω 99dB 15Hz-28kHz
Audio Technica unveils with the ATH-M50xBT2, the second-generation of Bluetooth headphone in its ATH-M series. As a wireless version of the ATH-M50X, it offers the same performance and sound signature. It incorporates 45mm wide-aperture transducers offering clear, immersive sound and enabling a wide frequency response from 15Hz to 28kHz and 99db sensitivity. At 38Ω, it can be driven by most of your source devices. The ATH-M50xBT2 manages to offer sound quality worthy of studio standards with wireless functionality.
Reference : 18002
199,00 €tax incl.
165,83 € tax excl.
AUDIO-TECHNICA ATH-M50xBT2
Closed-Back Dynamic Audio Headphone Bluetooth 5.0 Ø45mm 38Ω 99dB 15Hz-28kHz
AUDIO-TECHNICA ATH-M50XBT2 Casque Audio Dynamique Fermé Bluetooth 5.0 Ø45mm 38Ω 99dB 15Hz-28kHz
Bluetooth 5.0
With its Bluetooth functionality, the ATH-M50XBT2 supports LDAC, AAC and SBC codecs. This is made possible by an AK4331 32bit DAC chip featuring Velvet Sound technology optimized for wireless devices. The ATH-M50xBT2 also features a multipoint pairing function, allowing you to stay connected to two devices simultaneously for easy task switching.
This headphone is also equipped with dual microphones and spatial filtering technology for improved voice pickup and unrivalled audio quality for phone calls. In addition, the integration of its microphones enables communication with the built-in Amazon Alexa voice assistant.
The ATH-M50xBT2, an everyday ally
With a battery life of 50h on a full charge and up to 3h on a 10min fast charge via USB-C connector, the ATH-M50xBT2 is the perfect everyday ally. A 1.2m wired connection cable is also supplied for use without Bluetooth.
In terms of ergonomics, there are buttons integrated on the headphone for simplified control of various tasks such as volume control and voice assistant activation (Amazon Alexa, Google Assistant, Siri).
ATH-M50XBT2 controls
1USB-C battery charging socket
2Operating status indicator lights
3Jack 3.5mm connector
4Volume -
5Power on/off - Play/Pause - Pick up phone calls
6Volume +
7Activate voice assistant / Mute microphone during a call
Quality transducers
Like those of the ATH-M50x, the ATH-M50xBT2's transducers are designed with neodymium magnets and a CCAW (copper-coated aluminium) voice coil. With 45mm diameter transducers, the soundstage of Audio Technica's headphones is wide and detailed. The CCAW coils ensure a perfect tonal and vibratory balance.
A dedicated app for additional controls
The A-T Connect app gives you access to controls for a personalized listening experience. With this app, you can activate the low-latency mode, practical for gaming and video viewing, adjust the EQ, modify the L/R volume balance, select the voice assistant of your choice, locate your lost headphones or change the codec.
Product typeHeadphone
Headphone typeDynamic
Closed-back
Transducers diameter45mm
MagnetNeodymium
Voice coilCCAW (copper-coated aluminum)
Frequency response15Hz - 28Khz
Sensitivity99dB
Impedance38Ω
Battery typeDC 3.7V lithium polymer battery
Battery life50 hours of continuous playback
Charging tiime3.5h
Microphone typeMEMS
Microphone sensitivity-38dB (1 V/Pa, @ 1 kHz)
Microphone frequency response 85He - 15000Hz
Microphone directivity curveOmnidirectionnal
Wireless functionalityBluetooth 5.0
Max. communication distanceApprox. 10m
Compatible Bluetooth profilesA2DP, AVRCP, HFP and HSP
Supported Bluetooth codecsLDAC, AAC and SBC
Net weight (without cable)Approx. 307g
Package1* Audio Technica ATH-M50xBT2
1* Straight cable 1.2m Jack 3.5mm to Jack 3.5mm
1* USB-A to USB-C charging cable
1* Storage pouch
Impedance (Ω)38
Efficiency / Sensitivity (dB)99.0
Lowest frequency (Hz)15
Highest frequency (Hz)28000
WirelessNo
Cable terminationWireless
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
Headphone / Earphone connectorWireless (Bluetooth)
Audio Technica unveils with the ATH-M50xBT2, the second-generation of Bluetooth headphone in its ATH-M series. As a wireless version of the...
