The Audio-Technica ATH-S300BT headphones, big brother of the ATH-S220BT, are closed, dynamic wireless headphones whose main strength lies in their 90-hour battery life, without sacrificing the quality of the sound they deliver. In fact, a Ø40mm transducer delivers clear, immersive sound for a qualitative listening experience, whether musical or cinematic. Other features include multipoint connectivity via Bluetooth 5.1, hybrid digital noise reduction and an integrated microphone. In addition to its wireless connectivity, Audio-Technica has equipped its ATH-S300BT headphones with a 3.5mm jack for wired listening. There's also a USB-C port for recharging, with fast charging providing 2.5 hours of autonomy in just 3 minutes of charging.
The main strength of the Audio-Technica ATH-S300BT headphones lies in their battery life, which offers up to 90 hours of use. In addition, the quick charge feature allows you to gain up to 2h30 of autonomy in just 3 minutes. This makes the ATH-S300BT the perfect ally for everyday use and travel.
Ambient noise is reduced thanks to the integration of small MEMS microphones within the headphones' shells. When activated, noise reduction is achieved by both anticipation and feedback, for greatly optimized rendering. On the other hand, the “hearthrough” function lets you remain attentive to the outside environment.
The ATH-S300BT features Bluetooth 5.1 functionality and supports AAC and SBC codecs for reliable, stable reception at ranges of up to 10m. In Bluetooth mode, it's also possible to enjoy multipoint pairing for the smoothest possible experience. A 3.5mm jack input enables wired listening if required. A 3.5mm jack to 3.5mm jack termination cable with microphone is supplied. In wired mode, the ATH-S300BT headphones are easy to drive, given their 44.5 ohm impedance and 103dB sensitivity, making them ideal for use with a wide range of sources.
| Specifications | |
| Product type | Headphones |
| Headphones type | Closad-back dynamic |
| Transducer dimensions | Ø40mm |
| Frequency response | 20Hz-20kHz |
| Sensitivity | 103dB/mW |
| Impedance | 44.5Ω |
| Autonomy | Continuous music playback: Up to 60 hours (Bluetooth and noise reduction enabled)* Up to 90 hours (Bluetooth and noise reduction deactivated)* * These data depend on operating conditions. |
| Charging time | Approx. 2h30 * * These data depend on operating conditions. |
| Battery time | 3.85V DC (Lithium-Polymer battery) |
| Microphone type | Headphone: MEMS Cable: condensator |
| Microphone directivity curve | Headphones: omnidirectional Cable: omnidirectional |
| Microphone frequency response | Headphones: -38dB (1V/Pa, at 1 kHz) Cable: -42dB (1V/Pa, at 1 kHz) |
| Bluetooth version | Bluetooth 5.1 |
| Supported Bluetooth codecs | SBC, AAC |
| Frequency band | 2.402GHz - 2.480GHz |
| Compatible Bluetooth profiles | A2DP, AVRCP, HFP, HSP |
| Transmission method | FHSS |
| Content protection method | SCMS-T |
| General | |
| Color | Black |
| Weight | 258g |
| Package | 1x Audio-Technica ATH-S300BT headphones 1x 3.5mm jack cable to 3.5mm jack termination with microphone 1x USB-A to USB-C cable |
| Color | Black |
| Impedance (Ω) | 44.5 |
| Efficiency / Sensitivity (dB) | 103.0 |
| Lowest frequency (Hz) | 20 |
| Highest frequency (Hz) | 20000 |
| Wireless | Yes |
| Cable termination | Jack 3.5mm |
| Headphone / Earphone connector | Jack 3.5mm |
| Headphone / Earphone connector | Wireless (Bluetooth) |
