FOSI AUDIO I5 ONLINE VERSION Headphones
The Fosi Audio I5 Online Version is an open-air Planar Magnetic headphone. They feature a diaphragm no less than 97mm in diameter, offering a wide soundstage. Each driver incorporates a double array of balanced Neodymium N50 magnets for precise, stable diaphragm vibration. This greatly reduces any form of distortion for a clear, authentic sound reproduction. The earcup structure is made of CNC-machined aluminum, combining robustness and pleasing aesthetics.
By buying this product you get 54 loyalty points
Reference : 20959
549,00 €tax incl.
457,50 € tax excl.
Shipping date: 16-04-2026.
Fosi Audio I5 Online Version Open-Back Planar Magnetic Headphones Jack 3.5mm 28 ohm 98dB 10Hz-50kHz
Photo of FOSI AUDIO I5
The Fosi Audio I5 Online Version is an open-air Planar Magnetic headphone. They feature a diaphragm no less than 97mm in diameter, offering a wide soundstage. Each driver incorporates a double array of balanced Neodymium N50 magnets for precise, stable diaphragm vibration. This greatly reduces any form of distortion for a clear, authentic sound reproduction. The earcup structure is made of CNC-machined aluminum, combining robustness and pleasing aesthetics. Silky pads and a leather headband complete the structure, providing optimum wearing comfort. With its 28 ohm impedance and 98dB sensitivity, the I5 is relatively easy to drive, although it will require a good amplifier capable of delivering over 250-500mW of power. In addition, its dynamic range from 10Hz to 50kHz offers the most immersive listening experience. The package is completed by a detachable audiophile-quality 3.5mm jack cable with 6.35mm jack adapter for compatibility with the majority of HiFi equipment available on the market.
Fosi Audio I5: 97mm magnetic planar diaphragm
The Fosi Audio i5 headphones feature an advanced 97mm planar diaphragm, using an ultra-thin membrane just 2 microns thick. This extreme thinness allows the diaphragm to react with remarkable speed and precision, dramatically reducing distortion and delivering crystal-clear sound reproduction. The diaphragm is suspended between two rows of N50 neodymium magnets, arranged in a balanced push-pull arrangement, ensuring uniform magnetic force across its entire surface. This design guarantees perfectly controlled diaphragm movement, with extended frequency response (up to 50kHz) and excellent dynamics, even at high volume. The result is a surgically precise sound, with fine reproduction of micro-detail and a very airy soundstage worthy of much more expensive headphones.
FOSI AUDIO I5 planar magnet diaphragm photo
Fosi Audio I5: Extremely comfortable headphones
The Fosi Audio i5 also stands out for its excellent level of comfort, designed for long listening sessions. Despite its imposing size, its well-balanced structure and top-of-the-range materials ensure both sturdiness and comfort. The shape-memory metal headband adapts naturally to the user's morphology, distributing weight evenly to avoid pressure points. The circum-auricular ear pads are covered with a soft, breathable fabric, providing good insulation while allowing air to circulate, thus limiting heating. The chassis combines anodized aluminum and genuine walnut wood shells, offering elegant aesthetics and a premium quality feel in the hand and on the ears. This attention to construction makes the i5 as pleasant to use as it is to listen to.
FOSI AUDIO I5: comfortable headphones
FOSI AUDIO I5 cable
Fosi Audio I5: A detachable audiophile cable
The Fosi Audio i5 comes with a detachable 3.5mm dual-mono audio cable, ensuring both versatility and reliability. This high-quality braided cable is designed to minimize interference and signal loss, guaranteeing clear, faithful audio transmission. Its flexibility and light weight make it pleasant to handle, while offering good resistance to wear and tear for everyday use. Thanks to its standard 3.5mm TRS termination, the i5 can be easily connected to a wide range of audio devices - smartphones, Hi-Res players, portable DACs or headphone amps - and a 6.35mm adapter is included for immediate compatibility with salon or studio equipment.
Please note that a Fosi Audio I5 headphone version is also available with a detachable balanced 4.4mm jack cable.
Review of the Fosi Audio I5 headphones by Qobuz
"For this first i5 model, Fosi Audio has carefully studied its competitors while creating a unique and innovative headset. Its audio qualities place it at the top of the best planar magnetic models under €1,000: beautiful midrange, overall ambiance, and bass articulation. What's more, they are exceptionally well made. Versatile, they nevertheless require a high-quality headphone amplifier, preferably one that is firm and powerful, to get the most out of them. The Fosi Audio i5 is an excellent choice in the field of open-back headphones for stationary listening."
Qobuz
Product typeHeadphone
Headphone typeCircum-aural open-back
DiaphragmPlanar Magnetic
Max. SPL≥ 120dBSPL
Frequency response10Hz-50kHz
Sensibility98dB/mW @ 1kHz
Nominal impedance28 ohm
Recommended driving power≥ 500mW
Recommended minimum power100mW
Detachable cable
Cable length1.5m
Cable conductor materialOFC 5N silver-plated copper
Headphone connector2x Jack 3.5mm mono
Cable terminaisonJack 3.5mm stéréo
Weight550g
Dimensions16 x 24 x 11.5cm
Package1x Fosi Audio I5 headphones
1x Detachable 3.5mm jack cable
1x 3.5mm jack to 6.35mm jack adapter
ColorWood
Impedance (Ω)28
Efficiency / Sensitivity (dB)98.0
Lowest frequency (Hz)10
Highest frequency (Hz)50000
WirelessNo
Cable terminationJack 3.5mm
Headphone / Earphone connectorJack 3.5mm
FOSI AUDIO I5 ONLINE VERSION Open-Back Planar Magnetic Headphones Jack 3.5mm 28 Ohm 98dB 10Hz-50kHz
The Fosi Audio I5 Online Version is an open-air Planar Magnetic headphone. They feature a diaphragm no less than 97mm in diameter, offering a wide...
