HIFIMAN HE1000 UNVEILED Headphones
With the HE1000 Unveiled, Hifiman offers us planar magnetic headphones that redefine what open headphones are. In order to eliminate any distortion caused by the refraction of sound waves, Hifiman has opened up the backs of the drivers to an unprecedented degree, highlighting furthermore the design qualities of the nanometric diaphragm and the stealth magnet network for a crystal-clear result.
By buying this product you get 239 loyalty points
Reference : 19929
2 399,00 €tax incl.
1 999,17 € tax excl.
Shipping date: 13-05-2026.
HiFiMAN HE1000 Unveiled Planar Magnetic Open-Back Headphones Circum-Aural 28Ω 95dB 8Hz-65kHz
HE1000 Unveiled photo
With the HE1000 Unveiled, HiFiMAN offers us planar magnetic headphones that redefine what open-back headphones are. In order to eliminate any distortion caused by the refraction of sound waves, HiFiMAN has opened up the backs of the drivers to an unprecedented degree, highlighting furthermore the design qualities of the nanometric diaphragm and the stealth magnet network for a crystal-clear result.
HiFiMAN HE1000 Unveiled: Nanometre-scale diaphragm
First and foremost, it's important to underline that planar magnetic technology is at the heart of the HE1000 Unveiled. This technology is based on the diaphragm being completely covered by the voice coil, so the diaphragm vibrates uniformly, greatly reducing phase distortion, widening the soundstage and enabling more accurate spatialisation of sound. To this principle, Hifiman adds a nanometre-thick diaphragm, greatly improving response time and dynamics as well as the frequency range of sound reproduction.
HE1000 Unveiled : Nanometric membrane
HE1000 Unveiled : opening
HiFiMAN HE1000 Unveiled: A truly open headphone
The design philosophy of open-air headphones has always been to leave the backs of the drivers open so as to avoid refractions of sound waves. However, the grid design traditionally used, although sufficient in most cases, is not optimal and still causes refractions that affect the overall quality of the sound. Hifiman presents a window opening design devoid of grids, designed to optimise the evacuation of sound waves, thus avoiding refraction and improving sound quality by reducing distortion.
HiFiMAN HE1000 Unveiled: Magnetic Veil
Given the HE1000 Unveiled's unprecedented degree of openness, it comes with a pair of magnetic veil that can be used to protect the headset from any metal objects that might get inside when you're not using it.
HE1000 Unveiled : Magnetic veil
HiFiMAN HE1000 Unveiled: Magnet design invisible to the ear
The HE1000 Unveiled also stands out for the attention paid to its magnet network. One of the specific features of planar magnetic headphones is the positioning of magnets on both sides of the diaphragm, so the presence of these magnets can interfere with the sound produced by the diaphragm. In response to this problem, Hifiman has developed a stealth magnet array that allows sound waves to pass through without generating interference, diffraction or turbulence, resulting in a furthermore accurate, broadband sound reproduction.
HE1000 Unveiled :Explanatory diagram of the magnet array
HE1000 Unveiled : View of the inside of the headphones
HiFiMAN HE1000 Unveiled: Real wearing comfort
When designing the HE1000 Unveiled, we also paid particular attention to comfort. The headphones' earcups, for example, are asymmetric and bevelled to adapt as closely as possible to the natural shape of the ear and to distribute the weight of the headphones evenly, guaranteeing long listening sessions without the slightest discomfort.
HiFiMAN HE1000 Unveiled: High-quality cables
The HE1000 Unveiled comes with 3 high-quality cables with single-crystal copper and silver conductors to ensure faultless conductivity and signal transmission. The cables supplied have 3.5 mm jack, 6.35 mm jack and XLR terminations respectively, so they are suitable for all situations.
HE1000 Unveiled : Cables supplied
Technicals caractheristics
Product typeHeadphone
Headphone typeOpen back
Headphone formatCircum-aural
Headphone technologyPlanar Magnetic
Impedance28Ω
Sensitivity95dB
Frequency response8Hz-65kHz
Weight450g
ColorSilver
Package1x HiFiMAN HE1000 Unveiled
1x Pair of magnetic veils
1x 3m XLR 4-pin headphone cable
1x 3m 3.5mm Jack headphone cable
1x 1.5m 6.35mm Jack headphone cable
ColorSilver
Impedance (Ω)28
Efficiency / Sensitivity (dB)95.0
Lowest frequency (Hz)8
Highest frequency (Hz)65000
WirelessNo
Cable terminationJack 6.35mm
Cable terminationJack 3.5mm
Cable terminationXLR 4-pin
Headphone / Earphone connectorJack 3.5mm
HIFIMAN HE1000 UNVEILED Planar Magnetic Open-Back Headphones Circum-Aural 28Ω 95dB 8Hz-65kHz
With the HE1000 Unveiled, Hifiman offers us planar magnetic headphones that redefine what open headphones are. In order to eliminate any distortion...
