This product has been replaced by the new version, the Hifiman HE400SE Headphone.
Headphone driver planar magnetic single-ended 93dB
HIFIMAN HE400i 2020 edition inherits all the technological qualities of its predecessor. It carries the same formidably powerful planar magnetic drivers. A reworked structure makes it a light, comfortable headset with excellent support despite of its imposing drivers with massive diaphragms.
This model differs above all from previous versions by an unmatched value for money ratio. The HE400i 2020 indeed provides access to the best transducer technologies for headphones while remaining very affordable for limited budgets.
The drivers of the HE400i headphones benefit from a massive and ultra-light diaphragm offering an excellent time response with a rigorously controlled tonal balance. They can withstand strong input signals.
The headphones have a sensitivity of 93dB for an impedance of 35Ω, which allows operation both with a modest source (smartphone) as well as with headphone amplifiers capable of developing significant power.
The HE400i is above all a headphone with an impeccable design that measures itself against the market leaders. Its shells are in ABS polymer with a very modern glossy black finish.
The earlets are made of synthetic leather with velor pads, ensuring both comfort and optimal support while helping to isolate external noise. The contact points with the head are specially arranged to limit wear fatigue.
The set weighs only 370g.
Specifications | |||
Type | Headphone | ||
Technology | Planar Magnetic | ||
Driver | Single ended | ||
Frequency response | 20Hz - 35kHz | ||
Impedance | 35Ω | ||
Sensibility | 93dB | ||
Inlet | Jack 3.5mm | ||
Cable length | 1.5m | ||
Weight | 370g |
Color | Black |
Impedance (Ω) | 35 |
Efficiency / Sensitivity (dB) | 93.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 35000 |
