Casque Planar Magnetic 95dB 16 Ohm 20Hz-40kHz
Sendy Audio unveils the Apollo, an exceptional headset using Planar Magnetic technology for an incredibly accurate and precise sound. The luxurious wood and metal design conceals a true concentrate of technology, designed to offer the most faithful and richest sound reproduction possible, for the most immersive listening experience.
The Planar Magnetic drivers in the Apollo headphones use Quad-Former technology. This means that each diaphragm has dual magnets and dual coils on each side for a total of 4 coils per diaphragm. The coils are evenly distributed over the entire surface of the diaphragm. This design allows to obtain an optimal diffusion, the whole membrane reacting in the same way for a given frequency. The double magnets allow to obtain an identical magnetic power on the whole field. The Sendy Audio Apollo thus presents an efficient conversion of electroacoustic energy, associated with extremely low distortion, very good coherence and optimal sound fidelity.
The diaphragm itself uses a composite material with high damping capacity, allowing for natural, smooth vocals and solid bass. The ultra-thin and very rigid material in charge of high frequency reproduction allows to reach 40kHz for brilliant and detailed highs.
The Sendy Audio Apollo also offers a beautiful design, with the headphones mixing both a steel mesh and a wooden surround. The holes in the shell, in addition to giving the headphones a special aesthetic, allow for acoustic optimization. The whole thing is precision-machined using a CNC (numerical control), then sandblasted, polished and painted.
The headband uses a goat leather covering and its design allows a comfortable wearing of the helmet. The cushions them integrate a foam with memory of form adapting perfectly to the contours of the ear. In addition, they are easily removable and therefore replaceable.
The Sendy Audio Apollo comes with a high quality detachable cable. The cable has braided OCC copper conductors for excellent signal transmission.
The headset also comes with a carrying case and a fabric pocket for storing the cable.
Product type | Headphone |
Headphone type | Planar Magnetic |
Headphone format | Over-ear |
Transducers diameter | Ø68mm |
Frequency response | 20Hz - 40kHz |
Sensitivity | 95dB ±3dB |
Impedance | 16Ω ±15% |
Cable length | 2m ±0.2m |
Connector | Balanced Jack 4.4mm |
Weight | 395g |
Package | 1x Sendy Audio Apollo 1x Balanced Jack 4.4mm cable 1x Carrying case 1x Cable storage bag 1x 4.4mm jack to 3.5mm jack adapter |
Color | Black |
Impedance (Ω) | 16 |
Efficiency / Sensitivity (dB) | 95.0 |
Lowest frequency (Hz) | 20 |
Highest frequency (Hz) | 40000 |
Wireless | No |
Cable termination | Jack 3.5mm |
Cable termination | Jack 4.4mm |
Headphone / Earphone connector | Jack 2.5mm |
