Bought it to make custom headphone extension cable. Flexible, the PVC is exterior is durable. Price is very reasonable for OCC copper.
Litz Cable UP-OCC Copper for Headphone Ø3mm
The Neotech NECE-3001 MKIII is a headset and IEM cable with 4 multi-stranded Litz UP-OCC copper conductors. Each conductor is insulated with a transparent PVC jacket.
Litz wire is a conductor with each strand electrically insulated by a polyurethane coating. This reduces the impact of the skin effect, i.e. a current that flows only on the surface of the conductor at high frequencies, as well as the proximity effect that increases resistivity. Such a design is particularly suitable for audio use as it improves the conductivity and limits the resistivity of the cable, resulting in excellent audio reproduction.
To achieve a good solder joint on this type of cable, it is best to remove the coating with a soldering flux.
Product type | Headphone / IEM cable |
Number of conductors | 4 |
Conductors material | UP-OCC Copper Litz wires |
Insulation material | PVC |
Color | Copper |
Quantity | Sold by the meter |
Diameter (mm) | 3.0 |
Shielding | No |
Section (mm²) | N/A |
Conductors material (Cable) | Copper |
Conductors Plating (Cable) | None |
Ground / Shielding | No |
Average votes 4.4 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Igor K.
Xavier P.
Martti S.
Thierry S.
Jean Pierre b.
