NEOTECH NEI-3004G Balanced Interconnect Cable
Neotech's NEI-3004G modulation cable is a symmetrical modulation cable incorporating 2 G-UPOCC composite conductors, a combination of OCC copper and graphene. This new conductor marks a significant advance, both in terms of research and industrial applications. The addition of graphene improves the stability of electrical signal transmission at high temperatures, while preserving the exceptional conductivity of OCC copper, so that performance remains intact, even at high voltages.
Reference : 19315
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 19-05-2026.
Câble vendu au mètre
NEOTECH NEI-3004G Balanced Interconnect Cable G-UPOCC Graphene Ø8.5mm
NEOTECH NEI-3004G : macro view
NEOTECH NEI-3004G : Details of cable composition
The conductors have polyethylene insulation, preventing any transmission of electrical discharge created by the double mylar/aluminium shielding and OCC copper foil. The whole assembly is encased in a sheet of paper with cotton fibres for mechanical strength, then covered with a robust, flexible PVC sheath.
Product typeBalanced interconnect cable
Conductor materialUP-OCC copper with graphene (G-UPOCC)
Conductors2x multi-strand conductors
InsulationPolyethylene
PVC outer sheath
ShieldingAL MYLAR aluminum foil
OCC braided copper foil
Textile paper
External diameterØ8.5mm
ColorRed
PackageSold by the meter
Diameter (mm)8.5
Number of conductors2
Insulation materialPE
ShieldingYes
Section (mm²)N/A
Conductors material (Cable)Graphene
Ground / ShieldingYes
10 reviews
Un rapport qualité/prix exceptionnel, en sub comme en modulation
Excellent rapport qualité/prix pour ce NEI-3004G.
Le montage en DIY est particulièrement aisé, notamment avec les connecteurs ViaBlue T6s (Screw) qui permettent un montage par vissage direct.
Pour mon caisson de basses, j'ai opté pour un montage en double section (conducteurs rouge et bleu couplés sur le point chaud, tresse de blindage pour la masse). L'apport du graphène est immédiat : on gagne en impact et en vitesse, tandis que la structure UP-OCC garantit une grande transparence.
Écouté en modulation dans ces mêmes conditions, il excelle également. Le recul du seuil de bruit de fond apporte une image mate (absence de brillance artificielle) et un son nettement plus détouré. À moins de 50 €, c’est une véritable aubaine pour optimiser son système avec précision.
This review has been posted for NEOTECH NEI-3004G Balanced Interconnect Cable G-UPOCC Graphene Ø8.5mm
Very nice cable
The sound is neutral, clear and very open. With this level of transparency this definitely is a bargain. Thanks to Audiophonics and the reviewers to bring the attention to this cable.
It has arrows for the direction, but they are hard to see. I think it is just a handy feature to find back the side where you put the shield to the ground. I didn’t read anything about directionality. I build them the wrong way but these cables sound so good that I cannot believe I made a mistake to make them the other way around.
F.A.
Very transparent and dynamic cable with lots of detail and ambience. Top quality/price ratio. recommended!
My current favorite interconnect
To me this is not a tuning cable but a clear and unobstructed pathway to the source and easy enough to assemble.
It sits between my Wadia 12 DAC and my Carat A57 amplifier via XLR (+phase and ground only)
super *****
Neotech's NEI-3004G modulation cable is a symmetrical modulation cable incorporating 2 G-UPOCC composite conductors, a combination of OCC...
