NEOTECH NEMOI-1220 Dual Shielded UP-OCC Silver Interconnected Cable Ø10mm
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation cable, combining PTFE insulation and UP-OCC Silver conductors with rectangular cross-section, has a special architecture that significantly reduces the inductance and capacitance effect.
Reference : 13584
149,00 €tax incl.
124,17 € tax excl.
Shipping date: 02-07-2025.
Câble vendu au mètre
NEOTECH NEMOI-1220
Shielded UP-OCC Silver Interconnect Cable Ø10mm
NEOTECH NEMOI-1220 Câble de Modulation Argent UP-OCC Blindé Ø10mm
If you are looking for a very high quality modulation cable with a flawless design, the Neotech NEMOI-1220 is for you. The result is surprising, combining with listening often contradictory qualities such as sitting in the bass and a readable, natural sound scene with high definition in the medium, without auditory fatigue.
Product typeInterconnect cable
Matériau conducteursCross-Section UP-OCC Silver
Number of conductors2
Conductors section0.33mm²
ShieldingCopper-Mylar Foil + Braided Copper
InsulationPTFE + PE + PVC + Cotton
External sheathPE + PVC
Resistance0.054 Ohm/m
Capacity38.19pF/m
Inductance0.86µH/m
External diameter10mm
ColorBlue
QuantitySold per meter
Diameter (mm)10.0
Length (m)Sold by length
Insulation materialPE
Insulation materialPTFE
Insulation materialPVC
ShieldingYes
Section (mm²)0.33
Conductors material (Cable)Silver
Ground / ShieldingYes
17 reviews
l argent a fait mon bonheur
Fantastique cable .précis détaillé pas tres loin d être analytique tempéré dans mon système haut rendement par le furutech violet qui prend le signal en charge a la sortie du monoceros. Il fait donc la liaison entre le holo spring 3 et le monoceros.
L alliance entre l argent du neotech et le cuivre du furutech me plaît bien.Monté sur xlr EIZZ
This review has been posted for NEOTECH NEMOI-1220 Dual Shielded UP-OCC Silver Interconnected Cable Ø10mm
excellent silver cable
The cable is a big surprise for me. I was planning to replace the legendary Siltech SQ-110 Classic MK2, which I have been listening to for 20 years. The list price of the SQ-110 1m pair was 2600EUR. This NEMOI-1220 with DIY assembly at 1/6 of the price slightly surpasses the SQ-110 cable in sound already before burn-in.
A terrible negative is the peeling of the 0.1mm thick clear Teflon insulation covering the square silver conductor.
CABLE EXCEPTIONNEL.
Il faut être patient et méticuleux car sa structure est assez complexe.
Le résultat est excellent tant en XLR qu'en RCA.
Sur mon système, l'apport principal est sur la scène sonore et les timbres qui, tout deux, sont très naturels.
On est au dessus du Sommercâble Epilogue.
Incredible
I was a cable skeptic, thinking that a decent cable is more than enough for my KSE1200. I bought NEMOI 1220 cable out of curiosity mainly, after seeing all the reviews here.
Oh Boy, I wasn't prepared for all the changes I've got: more details, fuller and lusher (!) sound with better soundstage. Nothing like what people say about silver cables.
It's true that my previous cable was way cheaper, made with DCA16GA, but still, it's just a cable...
I'm impressed, I wish I tried this cable before.
Thank you audiophonics and to all those who post their reviews.
Amazing cable
This cable provides tons of detail without fatigue!. Impressive voices. It worths every penny. And certainly a big upgrade from my previous (a good cable of 60EUR/m). Totally recommended, just get it. Used it with EIZ rodium connectors - because I prefer screw than soldering on interconnects
The NEMOI series from the manufacturer Neotech is the result of extensive research in the field of audio cable. The Neotech NEMOI-1220 modulation...
