NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables.
The Neotech NEMOI 3220 modulation cable, combining PTFE insulation and OCC pure copper conductors with a rectangular section, has a special architecture allowing a strong reduction in the effect of inductance and capacitance.
If you are looking for a high resolution cable, the Neotech NEMOI 3220 can meet this expectation.
4.9 / 5
Reference : 11422
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 01-07-2025.
1MII B08+ Class D Amplifier Bluetooth 5.0 Receiver AAC SBCI QCC3034 2x50W / 4 Ohm
NEOTECH NEMOI-3220
BALANCED INTERCONNECT BRAIDED CABLE OCC PTFE Ø10MM
The result is surprising, combining listening qualities that are often contradictory, such as a seat in the bass and a readable, natural sound stage with High Definition in the midrange without auditory fatigue.
The shield can also be used as a conductor.
- Cable structure OCC Neotech NEMOI 3220 -
NEMOI-3320 Structure OCC Neotech
Technical characteristics :
  • 2 OCC copper conductors with rectangular section + 1 copper shielding sheath
  • 3-layer insulation : PTFE and Polyethylene in second layer, PVC outer sheath
  • Cable outer diameter: 10mm
  • Sold by meter
Diameter (mm)10.0
Length (m)Sold by length
Number of conductors3
Insulation materialPTFE
ShieldingYes
Section (mm²)N/A
Ground / ShieldingYes
16 reviews
En un mot... Majestueux !
Voici donc un avis qui emboîte le pas à celui que j'ai modestement rédigé concernant le Furutech FA-aS22.
Et pour peu que l'on évacue tout préjugé tarifaire, la divine surprise est à portée de main...
Ainsi, les Nemoi 3220 (tjrs soudés à la Mundorf Supreme sur des Switchcraft dont il a fallu réaléser à 10,5 mm les orifices des bouchons en alu) ont donc remplacés les FA-aS22 (ayant eux-mêmes plus de 50 heures au garrot) entre mes Nuprime DAC 9SE et STA 9X.
Si les vraiment "très bons premiers" m'avaient laissé sur un je ne sais quoi de frustration par un manque d'ampleur, je les ai donc troqués pour ces Nemoi 3220, juste "pour voir" (ou plutôt entendre) : à ce tarif-là, il est des tests qui ne se refusent pas...
...et alors là...
...je ne m'attendais absolument pas à cette musique-là !
Une matière retrouvée, des basses électriques, contrebasses et violes de gambe sensiblement plus étoffées dans leurs premières octaves avec une complexité harmonique sensiblement plus riche...
...des voix plus palpables matures et charnelles...
...des instruments à vent et à cordes (acoustiques et électriques) plus concrets...
Comme si, en fin de compte, ce gain en fréquences inférieures redonnait aux instruments cette fameuse complexité harmonique nous rapprochant de la vérité.
Le tout avec (et par compensation), il est vrai, un sentiment de léger recul du niveau des cymbales, mais, dans mon cas, en totale conformité avec la configuration mise en œuvre.
Bref, ce Nemoi 3220 contribue à une musique délicatement détaillée, envoûtante et "matérielle"...
Tout prend une place naturellement "en ordre", sans sentiment que telle partie du spectre bouscule ou phagocyte telle autre, me laissant à penser que les Nemoi 3220 sont un peu moins "audiophiles" et un peu plus "mélomanes" que les excellents FA-aS22.
Tout comme pour le Ludic Silenos, sans trop savoir pourquoi (et sans chercher à le comprendre non plus), ce sera sans doute le dernier.
Deux détails pour conclure :
- concernant son montage, bien veiller à considérer que les conducteurs sont constitués de monobrins en nappe doublement isolés : une fois dénudées les gaines rouges et bleues, reste sur chacun un isolant transparent à éliminer délicatement pour assurer un soudage digne de ce nom.
- ne surtout pas le juger "from scratch", car dans ce cas, il peut verser dans un chouïa de vulgarité, ce qui disparaît intégralement une fois franchies les 20 heures...
This review has been posted for NEOTECH NEMOI-3220 Balanced interconnect braided Cable OCC PTFE Ø10mm
Ce câble est bien dynamique, beau grave et bas médium.
Il met juste légèrement les aigus en arrière .
Il me fait pensé au câble secteur Furutech T 31 ( vert ) pour ses timbres .
Excellent câble symétrique
J'avais déjà réalisé des câbles RCA avec ce 3220 mais je n'avais pas vraiment d'autres câbles pour faire un comparatif.
J'ai réalisé deux câbles symétriques d'environ 80cm avec des connecteurs Viborg XM et XF 202G. Je l'ai comparé à des câbles que j'ai fait avec du câble Canare L-4E6S et les mêmes connecteurs (je les aime bien).
Ces câbles sont entre un DMP-A6 et un Hegel H190.
Avec le 3220, le son est plus plein, plus vivant. Les graves sont toujours là, plus percutant encore, le medium est mieux placé et les aigus se sont étoffés, sans être agressifs.
Les points chaud et froid (2 et 3) sont connectés des deux cotés. Le blindage (1) n'est connecté que du coté source, sur les deux câbles.
J'aime beaucoup ce câble.
 (5)
up occ copper cables
I ordered this cable after having very good results with the NEI 3004 interlink cable. I used for this cable the AECO pure copper RCA plugs.
I am curious what the NEMOI 3220 with AECO ARP-4045 RCA plugs will do in my setup. I will come back as soon as the interlink is ready and is listen at.
I have not been listening to it
Vraiment EXCELLENTS
J'ai eu une expérience malheureuse avec ces câbles branchés entre un petit dac Audio GD et mon ampli (AF 3S) et depuis ils dormaient au fond d'un tiroir. Mais je viens d'acquérir un lecteur CD (MT CD One) et par curiosité je les ai branchés entre le MT et l' AF 3S et là grosse surprise c'est vraiment excellent , une très grande transparence tout en étant chaleureux : parfait ! Et je comprends aujourd'hui qu'il faisait bien ressortir les défauts du dac Audio GD qui d'ailleurs est revendu depuis longtemps . Pour infos les fiches sont des RAMM AUDIO 30891
The NEMOI series from the manufacturer Neotech is the culmination of long research in the field of audio cables. The Neotech  NEMOI 3220...
