Pour l'instant à leur niveau qualité / Prix , je n'ai rien trouvé de mieux Très bon serrage et une solidité bien supérieure à tout ce que j'ai pu avoir précédemment. Je les recommande.
Rhodium Plated Ø9mm
These banana plugs, although inexpensive, benefit from a nice design quality. The design of these plugs allows a very good contact between the connector and the terminal block, as well as a perfect hold. The contacts are rhodium plated, ensuring good conductivity. Mounting is easy thanks to a screw system.
Product type | Banana plugs |
Contacts material | Copper alloy |
Contacts plating | Rhodium |
Max cable diameter | Ø9mm |
Max conductor diameter | Ø5mm |
Mounting type | to screw |
Max cable diameter (mm) | 9.0 |
Mounting type | To screw |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Rhodium |
Average votes 3.7 / 5 3 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Laurent P.
Brian C.
walter s.
