bonnes fiche bananes. Il ne faut pas craindre un rendu criard que pourrait occasionner le plaquage argent, ces fiches restent neutre dans la restitution.
Elecaudio has manufactured these bananas (BFA compatible) to meet a demand for quality, practical banana plugs at a very attractive price.
These bananas are made of "Direct Silver" plated Beryllium Copper (without Nickel underlay) and are also available in other versions:
These plugs are mounted by soldering, so that there is maximum contact between the conductor and the plug.
It is possible to obtain a clean finish by adding a 5/6mm thermo sheath between the cable and the plug.
Dimensions :
Sold by 4
Max cable diameter (mm) | 4.0 |
Mounting type | To weld |
Connectic | Male |
Connector | Banana |
Contacts Material (Connector) | Beryllium Copper |
Contacts Plating (Connector) | Silver |
Average votes 4.7 / 5 11 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Cedric J.
Patrick S.
Damien M.
Patrick R.
Anders L.
