FOSI AUDIO Banana Plugs 24k Gold Plated Copper Ø4mm (Set of 4)
Fosi Audio banana plugs feature 24k gold-plated copper contacts that offer excellent conductivity and minimize signal loss.
Reference : 21260
11,91 €tax incl.
9,92 € tax excl.
Fosi Audio Banana Plugs 24k Gold-Plated Copper Ø4mm (Set of 4)
Photo of Fosi Audio banana plugs
Fosi Audio banana plugs feature 24k gold-plated copper contacts that offer excellent conductivity and minimize signal loss. This gold plating also provides effective protection against oxidation and corrosion. The body is made of aircraft-grade aluminum alloy for enhanced durability. Easy to install with two screws, eliminating the need for soldering, they are ideal for DIY speaker cable projects or repairs.
Dimensions of Fosi Audio banana plugs
Product typeBanana plugs
Contact materialCopper
Contact platingOr 24k
Max. cable diameterØ8.8mm
Max. conductor diameterØ4mm
Identification ring
DimensionsØ11 x 55mm
Weight8g/banana plug
PackageSet x4
Max cable diameter (mm)8.5
Mounting typeTo screw
ConnecticMale
ConnectorBanana
