KLEI CLASSIC HARMONY BANANA Banana Plug Silver Plated Pure Copper Ø4mm (Set x8)
Following a long period of research and development by KLEI, the brand offers banana plugs with exceptional performance, thanks to pure copper contacts> 101 IACS and a silver plating.
Reference : 12488
105,00 €tax incl.
87,50 € tax excl.
Shipping date: 03-09-2025.
KLEI classic HARMONY Banana Plug KLE 1D
Silver Plated Pure Copper ⌀ 4mm (Set x8)
KLEI HARMONY Fiche banane cuivre plaqué argent
Exceptional materials
KLEI for the creation of its Harmony banana plugs has notably worked on maintaining the integrity of the signal and thus limiting its attenuation to a minimum. Thus, the choice of materials is an essential element, whether it is the structure or the contacts. The body is based on a heat-resistant, electrically inert polymer and has pure copper silver plated contacts.
Optimum Mass
To optimize the electron flow and define the materials to be used, KLEI uses a mathematical formula that relates signal to earth. The result is greater control, also avoiding the skin effect. This optimization ensures a wider frequency range and harmonics transported without deterioration from one point to another in your system.
The best metals
To optimize the conductivity of its banana plugs, KLEI chooses the best metals. We can find contacts made of pure copper > 101% IACS silver plated.
An efficient system
These Harmony banana plugs allow easy soldering. In addition, the connector format is also designed to be able to connect two plugs to a single plug, e. g. in the case of two-wiring.
Contacts materialPure Copper > 101% IACS
Pure Silver
Body materialHeat resistant thermoplastic
Connection typeSoldering
maximum acceptable cable diameter4mm (6AWG)
Package content4x red banana plug
4x black banana plug
Max cable diameter (mm)4.0
Mounting typeTo weld
ConnecticMale
ConnectorBanana
5 reviews
A recommander (vivement) !
Partisan du câble nu, forcé d'utiliser des fiches bananes côté ampli. Après plusieurs essais de différentes fiches, j'ai enfin trouvé celles qui me conviennent. Transparence incroyable. Le top !!!
This review has been posted for KLEI CLASSIC HARMONY BANANA Banana Plug Silver Plated Pure Copper Ø4mm (Set x8)
Superbe qualité sonore
Installées en remplacement de fiches Nakamichi laiton plaquées or. L'apport est net, belle douceur avec des timbres magnifiées. Le contrôle/lisibilité du grave est aussi amélioré.
Très satisfait donc du point de vue sonore. Le boitier plastique est d'assez bonne qualité bien qu'on ait une impression de fragilité au final. Une section de 4mm est bien possible mais attention, l'épaisseur de l'isolant du cable ne pourra bien-sur pas être emprisonné/serré par le boitier.
excellent!
je viens de d'installer ces fiches banane sur un câble audioquest relativement bas de gamme et je suis très agréablement surpris par le résultat sonore obtenu. La différence est plus que subtil!
La finition est certes un peu "cheap" mais pour celui qui cherche avant tout un nette gain sonore sans se ruiner c'est parfait
Tout à fait satisfait
Réception rapide après commande et emballage tout à fait adapté.
Fiche simple à utiliser, penser au fer à souder et à l'étain à l'argent pour la soudure, sinon ce sera sertissage.
Simple et efficace.
TRES SERIEUX
Super !
Produit livré dans les délais et parfaitement emballé.
Alain
Following a long period of research and development by KLEI, the brand offers banana plugs with exceptional performance, thanks to pure copper...
