LITHIUMWERKS Rechargeable Battery LifePO4 26650 3.3V 2500mAh (Unit)
This A123 Systems ANR26650M1-B rechargeable battery (or accumulator) has a LifePO4 chemistry. They have the advantage over conventional Li-Ion batteries of being more durable (higher number of charging cycles), less sensitive to partial charges and withstanding higher currents.
Reference : 14038
9,70 €tax incl.
8,08 € tax excl.
Shipping date: 20-08-2025.
3 >Month warranty
Lithiumwerks ANR26650M1-B
Lithiumwerks ANR26650M1-B Batterie Rechargeable LifePO4 26650 3.3V 2500mAh (Unité)
This Lithiumwerks ANR26650M1-B rechargeable battery (or accumulator) has a LifePO4 chemistry. They have the advantage over conventional Li-Ion batteries of being more durable (higher number of charging cycles), less sensitive to partial charges and withstanding higher currents. They are also more reliable and the voltage delivered during discharge is more stable. These batteries are also less polluting and can be stored for a longer period of time.
This model provides a voltage of 3.3V for a capacity of 2500mAH. It can be used on some power supply modules (sold separately) using batteries, the latter having the advantage of providing a cleaner and more stable electrical signal to audio devices and modules. Ideal for high quality audio playback.
A123 SYSTEMS ANR26650M1-B Batterie Rechargeable LifePO4 26650 3.3V 2500mAh (Unité)A123 SYSTEMS ANR26650M1-B Batterie Rechargeable LifePO4 26650 3.3V 2500mAh (Unité)
Product typeRechargeable battery
Battery typeLifePO4
Battery format26650
Capacity2500mAh
Nominal voltage3.3V
Internal impedance6mΩ
Recommended standard charge method1C to 3.6V CCCV, 45min
Recommended Fast Charge Method to 80% SOC4C to 3.6V CC, 12min
Maximum continuous discharge70A
Maximum pulse discharge (10 seconds)120A
Cycle life (décharge = 10C, 100% DOD)> 1000 cycles
Operating temperature-30°C / +55°C
Storage temperature-40°C / +60°C
ConnectorFlat top
DimensionsØ26 x 65mm
Weight76g
QuantitySold per unit
Rated voltage (V)3.3
Download
This A123 Systems ANR26650M1-B rechargeable battery (or accumulator) has a LifePO4 chemistry. They have the advantage over conventional Li-Ion...
