This 18650 Lithium-Ion battery from Panasonic is ideal for providing clean, stable, noise-free power to devices of equivalent voltage and current. For example, it can be used to power small Class D amplifiers such as Sure Electronics JABs, or as a rechargeable power supply for portable speakers.
To use this battery, you can combine it with the Sure AA-JA11113 18650 battery charger or the Allo Battery Pack 18650 lithium battery module.
Spécifications | |
Product type | Lithium-Ion battery |
Type | 18650 |
Connector | Flat Top |
Typical capacity | 3180mAh |
Min. capacity | 3080mAh |
Nominal capacity | 300mAh |
Nominal voltage | 3.6V |
Final charging voltage | 4.2V |
Final discharge voltage | 2.5V |
Charging curent | max. 1.5A |
Max. current output | 10A (10000mA) |
Charging method | CC-CV |
Diamèter | Ø18.50mm (± 0.1mm) + 65.30mm (±0.15mm) |
Weight | 49.5g (±1g) |
Package | 1x Panasonic NCR18650BD 18650 Lithium-Ion battery |
