SOMMERCABLE ELEPHANT SPM440 HP OFC cable 4x4.0mm² Ø 11mm
4.7 / 5
Reference : 723
10,00 €tax incl.
8,33 € tax excl.
Shipping date: 18-12-2025.
https://www.audiophonics.fr/images2/722/Elephant_4x40.gifmulticore
SOMMER CABLE - Elephant SPM440
https://www.audiophonics.fr/images2/722/722_sommercable_Elephant_1.jpg
The cables are red ...
and la crowd roars when the loudspeaker volume is pushed to the maximum. Within reach of the climax, not only hearts are heated, but also conductors: they too are subjected to extreme tests, which means that the protective sheath must be as resistant as a skin d 'elephant. In addition they must be flexible, robust, easily rollable, crush resistant and must be able to withstand successive mountings and disassembly and a long service life.
By its technical constitution of quality equivalent to that of the hi-fi drivers, it retransmet clear highs like crystal and dynamic basses and without defects.
Make a comparison with other speaker cables: the ELEPHANT will convince you in all areas!
Now also available in halogen-free FRNC version (C mode approved)
ADVANTAGES:
  • Transmission of lossless signals due to specially formed cores
  • PVC version very flexible and suitable for stage installations
  • Compatible with standard Neutric-Speakon connectors
  • Easily rollable
  • Easy to use thanks to excellent insulation and numbered conductors
USE:
    • Professional acoustic installations
tional
  • Surround and woofer systems
  • Fixed building installations
Technical characteristics:
Constitution(4LIY4.0mm 2 ) Y
Envelope, diameter11.0 mm
AWG12
Number of Conductors4 x 4 mm 2
Envelope material, insulationPVC
Copper strands per coret = 225 x 0.15 mm
Conductor insulation, diameter3.75 mm
Operating temperaturemin. -30 ° C
Operating temperaturemax. 70 ° C
Fire resistance per m0.51 kWh
Weight per m273 g
Color of envelope black
style = "font-size: xx-small;"> Packaging, packaging unitper meter
Electrical Specifications:
Odometer Resistance, Conductor<4.5 Ohm
Resistance, insulation> 5 MOhm
Operating voltagemax. 300 V
Test voltage2 kV
Diameter (mm)11.0
Length (m)Sold by length
Number of conductors4
Insulation materialPVC
ShieldingNo
Section (mm²)4.00
Ground / ShieldingNo
7 reviews
Pour remplacer mon Sommercable Orbit 240 mkII 2x4mm2.
Remplace mon Sommercable Orbit 240 mkII en 2x4mm2 déjà excellent pour passer en bi-câblage ou en 2x8mm2.
Ce câble est agréablement très souple bien plus flexible que l'Orbit, facile à dénuder, diamètre extérieur identique à l'Orbit 4mm2 donc pas si gros (rond quand l'Orbit est plat).
Ecoute toujours chaleureuse, pas de dureté, c'est transparent, le rodage améliorera encore le son.
Au prix proposé au mètre, c'est une affaire exceptionnelle, j'ai testé de très nombreux câbles ésotériques pour m'arrêter sur Sommercable (en modulation le câble Sommercable Epilogue arrive en tête aussi).
Merci à Audiophonics pour la qualité de l'envoi !! (emballage et transport).
This review has been posted for SOMMERCABLE ELEPHANT SPM440 HP OFC cable 4x4.0mm² Ø 11mm
André .C
Depuis de très nombreuses années, j'utilisais du câble QED Bi anniversary en bi amplification passive sur un système composé d'enceintes NIL et de blocs de puissance ADVANCE.
J'ai voulu essayer le SOMMERCABLE SPM 440 au prix on ne peut plus abordable.
Quelle ne fut ma surprise en obtenant une plus grande spatialisation, ainsi qu'une plus grande finesse de son.
Des basses plus fermes, un registre médium / aigu beaucoup moins agressif.
J'ai monté ces câbles avec de la gaine nylon et des splitters, ce qui donne un effet pro.
Que dire du service AUDIOPHONICS, toujours au top sur toutes mes commandes. Commandé le jour J, reçu le jour J+1...attention au choix du transporteur !
Capable cable
High quality "standard" cable. Symmetric construction with a central cotton twine. The sheath and insulation are easy to strip. Sonically, they transmit a big soundstage with good 3D effect. The sound is cohesive with a slight warm fuzz. The base is very fluent. Good for playing loud as there is no harshness to the sound. Compared to my reference, solid single core copper, there is a slight veil and softer edge definition. All in all a capable cable that provides an entertaining sound. I'd use it more for parties or background listening, not so much for analytical listening.
Christio007
Per il prezzo non si può trovare di meglio!!! Prodotto eccellente, di facile lavorazione, non si può chiedere di più+++Suono neutro e piacevole+++++++++++++++++++++++++++Grazie a Audiophonics !!!!!!!!
Très bon câble, neutre et transparent.
Rapport qualité prix imbattable !
