ELECAUDIO BP-206 Gold Plated Binding Post Acrylic Isolated Ø19mm x 47mm Black
This high quality Elecaudio BP-206 terminal block uses gold-plated copper alloy as conductor, ensuring excellent conductivity and resistance to oxidation. The terminal block accepts banana plugs and forks (8mm) for quick and easy connections.
4.8 / 5
Reference : 3724
6,90 €tax incl.
5,75 € tax excl.
Elecaudio BP-206
Elecaudio BP-206 Bornier Isolé Acrylique Plaqué Or à Souder Ø19mm x 47mm Noir
This high quality Elecaudio BP-206 terminal block uses gold-plated copper alloy as conductor, ensuring excellent conductivity and resistance to oxidation. The terminal block accepts banana plugs and forks (8mm) for quick and easy connections. The terminal block is also fully isolated to limit the impact of interference on the signal.
Diagram
1Body (Gold plated Copper alloy)
2Nut (Gold plated Copper alloy)
3Washer (Nylon PA 66)
4Washer (Nylon PA 66)
5Shell (Polycarbonate)
6Shell (Polycarbonate)
7Ring (Gold plated Brass)
8Shell (Gold plated Brass)
9Color ring (PE207)
Product typeBinding post
Contact materialCopper alloy
Contact platingGold
Isolant body materialPolycarbonate
Max cable diameterØ5mm
Thread diameterØ8mm
Cutout diameterØ9mm
Max panel thickness10mm
Total length47mm
Diameter19mm
Banana plug compatibility4mm
Spades compatibility8mm
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)10.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
5 reviews
Presque Parfait
Déjà commandé pour deux autres projets DIY, la qualité est bonne, l'isolation par rapport au boitier est bonne je recommande.
attention toutefois si vous soudez directement dans l'âme il est parfois difficile que le flux de soudure adhère bien ! préférez peut être mettre une cosse
This review has been posted for ELECAUDIO BP-206 Gold Plated Binding Post Acrylic Isolated Ø19mm x 47mm Black
Excellente embase
Ces embases respirent réellement la qualité, elles ont un beau volume et poids et sont bien conçues d'une façon générale. J'ai vu des amplis haut de gamme être bien moins dotés que ces borniers.
Le serrage des câbles est très bien pensé car en plus de la partie extérieure à visser, un anneau interne mobile va éviter de "frotter" les brins du câble, et va assurer un serrage bien ferme.
La soudure à l'argent n'est pas évidente, veillez à bien retirer toute la plastiquerie avant de vous mettre aux soudures, car vous devrez chauffer FORT et LONGTEMPS.
Très Bon produit
Très beau produit, lourd et massif.
Attention soudure délicate, il faut un mini chalumeau pour faire un travail propre . Un simple fer à souder ne suffit pas à monter la pièce en température pour une bonne prise de la soudure ! Ne surtout pas oublier d'enlever toutes les pieces en plastiques avant de les souder....sinon belle fondue en perspective !!
Excellent !
Franchement c'est vraiment une borne très grande qualité.
Je suis très content et a tous je vous recommande cette borne.
super bornier génial
Bornier elecaudio BP 206 isolé facile à monté vraiment pratique en rodage année 2015 merci
This high quality Elecaudio BP-206 terminal block uses gold-plated copper alloy as conductor, ensuring excellent conductivity and resistance to...
