VIBORG BP-603 Pure Copper Speaker Terminals Plug Ø4.5mm (Set x4)
With its BP-603, Viborg offers exceptional terminal blocks for speakers, thanks to a design using particularly high-end materials.
Reference : 12743
85,00 €tax incl.
70,83 € tax excl.
Shipping date: 01-07-2025.
Viborg BP-603
Speaker Terminals Pure Copper ⌀4.5mm
viborg BP-603 borniers enceintes
Thus, the contact material of the terminal block is made of Pure Copper, which is not without attention. Indeed, copper is an excellent conductor, more efficient than gold. In addition, the use here of Copper, characterized by a "dew" colour, gives the connector an original and elegant aesthetic. Viborg also incorporates a brass body to properly protect the connector for longer life. On the practical side, the terminals can either be screwed or receive banana plugs.
In short, these speaker terminals are fully adapted to fit into a high-end HiFi audio system.
ConductorPure Copper
Housing materialBrass
Accepts banana plugsYes
ConnectionTo screw / To solder (hexagonal socket screw 2mm)
Cable diameter4.5mm
Housing dimensions15 x 21mm
Max panel thickness3.6mm
Drilling diameter11.5mm
Length48.8mm
Mounting typeTo screw
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)3.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
3 reviews
andrew
Amazing quality a big difference than same production from AliExpress.
This review has been posted for VIBORG BP-603 Pure Copper Speaker Terminals Plug Ø4.5mm (Set x4)
Very nice and good quality speaker terminals.
Vincent
Très belle fabrication. Le matériau assure la continuité avec le câble en cuivre en interne et la fiche banane cuivre de l'autre côté. Et ça fait bien une différence à l'écoute avec le bornier précédent en laiton.
 (4)
