VIBORG BP-604 Binding Post Pure Copper Ø4.5mm (Set x4)
The Viborg BP-604 are very good terminal blocks, ideal for high quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal conductivity.
Reference : 12770
129,00 €tax incl.
107,50 € tax excl.
VIBORG BP-604
Viborg BP-604 borniers
The Viborg BP-604 are very good terminal blocks, ideal for high quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to offer an optimal signal conductivity. In this same perspective, in order to protect the audio signal as much as possible, the connectors are insulated with Nylon and Polycarbonate.
In addition, this model has a body based on carbon fiber, POM and copper alloy giving it a strong design.
Finally, on the practical side, the connectors accept banana plugs and mounting is facilitated since the cable can be held by a screw.
Conductor materialPure copper
Housing materialCarbon fiber, POM, copper alloy
InsulationNylon
Polycarbonate
Connection typeTo screw / To solder
Acceptable cable diameter4.5mm
Drilling diameter11.45mm
Housing dimensions11.5 x 23.4mm
Total length54mm
Mounting typeTo weld
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)11.5
Accepts Banana PlugsYes
ConnectorSpeaker terminal
The Viborg BP-604 are very good terminal blocks, ideal for high quality DIY assemblies. Indeed, they integrate a pure copper conductor in order to...
