TINYSINE Bluetooth Antenna 2.4GHz U.FL 4dBi Flat PCB
This Bluetooth antenna on a flat PCB has an operating frequency of 2.4GHz and a gain of 4dBi. Its U.FL connector will allow you to connect it to small DIY modules offering this connector to enjoy better Bluetooth reception.
Reference : 13816
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 06-05-2025.
TinySine Bluetooth Antenna
2.4GHz U.FL Flat PCB 4dBi
TinySine Antenne Bluetooth 2.4GHz U.FL PCB Plat 4dBi
This Bluetooth antenna on a flat PCB has an operating frequency of 2.4GHz and a gain of 4dBi. Its U.FL connector will allow you to connect it to small DIY modules offering this connector to enjoy better Bluetooth reception. The back of the PCB has a 3M double-sided strip for easy mounting.
Product typeBluetooth Antenna
ConnectorU.FL
Frequency2.4 - 2.7GHz
Gain4dBi
S.W.R<= 2.0
PolarizationLinear
Impedance-50Ω
LengthWith PCB : 17.5cm
Cable only: 12.5cm
OutputU.FL
3 reviews
Très bien
Mis en interne dans un boitier, bonne réception. Vu le prix, pourquoi s'en passer.
This review has been posted for TINYSINE Bluetooth Antenna 2.4GHz U.FL 4dBi Flat PCB
Einwandfreier Empfang
Stecker passt und der Empfang ist einwandfrei.
Augmente considérablement la portée de mes récepteurs BT.
Le connecteur fonctionne parfaitement.
Alors vu le prix pourquoi s'en passer.
This Bluetooth antenna on a flat PCB has an operating frequency of 2.4GHz and a gain of 4dBi. Its U.FL connector will allow you to connect it to...
