TINYSINE TSA6178 Bluetooth 5.0 Receiver Board aptX SPDIF Coaxial Output
This TinySine TSA6178 Bluetooth 5.0 receiver with coaxial SPDIF output will allow you to stream and control your music remotely from your smartphone or connected tablet. The integrated AudioB Digi module supports the aptX transmission codec, for a quality sound reproduction.
Reference : 15974
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 02-04-2026.
TinySine TSA6178
Bluetooth 5.0 aptX Receiver Module
TinySine TSA6178 Module récepteur Bluetooth 5.0 aptX
This TinySine TSA6178 Bluetooth 5.0 receiver with coaxial SPDIF output will allow you to stream and control your music remotely from your smartphone or connected tablet. The integrated AudioB Digi module supports the aptX transmission codec, for a quality sound reproduction. In addition, the module also has a line input in 3.5mm jack format
The TSA6178 automatically detects the input signal. Bluetooth has a higher priority. When Bluetooth is disabled or if no signal is received, the TSA6178 automatically switches to line input.
Product typeBluetooth receiver
InputBluetooth 5.0
Outputs1x SPDIF Coaxial
1x Jack 3.5mm
Supported Bluetooth codecsaptX
Other technologiesQualcomm cVc
Qualcomm TrueWireless
Max tranmission distance15m
Supply voltage5VDC via Micro USB
Dimensions180 x 33 x 54mm
OutputCoaxial SPDIF
OutputJack 3.5mm
This TinySine TSA6178 Bluetooth 5.0 receiver with coaxial SPDIF output will allow you to stream and control your music remotely from your...
