1MII LAVAUDIO B03PRO+ Receiver Transmitter Bluetooth 5.0 aptX HD LDAC CSR8675 DAC ES9018Q2C
The 1Mii B03Pro+, evolution of the B03Pro, is like its big brother a particularly versatile and powerful Bluetooth receiver and transmitter, always proposed at a contained price. Its meticulous and optimized design allows it to ensure a sound restitution of great quality, in particular thanks to a powerful Bluetooth chip and a conversion stage based on a DAC tested and recognized by the audiophiles.
Reference : 16989
109,00 €tax incl.
90,83 € tax excl.
Shipping date: 07-05-2025.
1Mii B03Pro+
1Mii B03pro+ Récepteur Émetteur Bluetooth 5.0 aptX HD LDAC CSR8675 ES9018Q2C
No latency
The aptX Low Latency technology eliminates the delay when transmitting an audio signal over Bluetooth for perfectly synchronized listening. The Dual Link function allows the broadcasting on two headphones or two speakers in a completely synchronized way.
High definition audio
With support for the Bluetooth aptX HD and LDAC transmission codecs, the 1Mii B03Pro+ is capable of delivering sound quality at least equal to that of CDs, if not better, and this wirelessly.
An LCD screen for intuitive operation
The 1Mii B03Pro+ has an LCD screen that displays the main information related to its use. Thus, this one indicates you the connected devices, the type of codecs currently used, the level of volume or the mode of transmission.
ESS ES9018Q2C DAC
Widely recognized by audiophiles, the ESS ES9018Q2C DAC chip allows you to enjoy a rich and precise reproduction. It ensures a signal-to-noise ratio of 121dB while supporting PCM streams up to 32bit 384kHz.
Bluetooth 5.0
At the heart of the 1Mii B03Pro+ is a Qualcomm CSR8675 Bluetooth 5.0 chip, a high-performance solution designed to ensure quality audio reproduction. This one ensures a clean and stable transmission and reception of the signal.
Additional connectivity
The B03Pro+, in addition to its Bluetooth connectivity, offers in input and output a 3.5mm jack and optical Toslink.
3 operating modes
Versatile, the 1Mii B03Pro+ can be used in 3 different modes, in order to adapt to everyone's needs: receive, transmit and bypass.
Transmitter mode
The 1Mii B03Pro+ can be used as a Bluetooth transmitter. In this mode, you can transmit an audio stream to an audio device, TV, AV receiver, headphones, speakers or any other audio source device with Bluetooth connectivity.
Receiver mode
In receiver mode, the B03Pro+ can receive a Bluetooth audio stream from a connected device, such as a smartphone, tablet or computer.
Bypass mode
FFinally, bypass mode connects an input directly to an output, disabling the receive and transmit functions.
Bypass mode allows you to use the device in wired mode and disable Bluetooth: Optical to Optical, or Jack 3.5mm to Jack 3.5mm.
Product typeBluetooth Émetteur / Récepteur Bluetooth
EntréesBluetooth 5.0
1x Optique Toslink
1x Jack 3.5mm
SortiesBluetooth 5.0
1x Optique Toslink
1x Jack 3.5mm
Puce BluetoothQualcomm CSR8675
Puce DACESS ES9018Q2C
Version Bluetooth5.0
Profils Bluetooth supportésA2DP
AVRCP
Codecs Bluetooth supportésSBC
AAC
aptX
aptX LL
aptX HD
LDAC
Distance de transmission maxSans obstacle : 30m
Package1x 1Mii B03Pro+
1x Câble USB-A vers USB-C
1x Câble Jack 3.5mm vers RCA
1x Câble Jack 3.5mm
1x Câble Optique
1x Adaptateur secteur
InputJack 3.5mm
OutputOptical Toslink
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipES9018Q2C
Supported Bluetooth codecsAAC
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsSBC
4 reviews
Polyvalent
Permet l’émission ou la réception en Bluetooth. Il est vraiment très petit. Configuration hyper simple, le Bluetooth est reconnu sans problème. Fonction volume et pause. Tous les câbles sont livrés avec.
Utilisé entre un iPhone/iPad et une vielle chaine Hifi des années 90, fonctionne à merveille.
This review has been posted for 1MII LAVAUDIO B03PRO+ Receiver Transmitter Bluetooth 5.0 aptX HD LDAC CSR8675 DAC ES9018Q2C
Parfait en mode transmetteur LL
Je l'ai acheté pour envoyer le son de mon vidéo projecteur vers mon ampli à 2m50 à vol de mouche.
Je l'utilise en transmetteur mode Low Latency, c'est le mode alternatif à LDAC en transmission, et ça marche très bien. Aucun problème de latence.
Et pas de perte de puissance de son à relever, même si je pense que ça dépend plus du récepteur, mais au moins c'est constaté.
Et puis quel pied d'avoir l'écran pour choisir le périphérique auquel se connecter !!! Connexion rapide et automatique, parfait.
Tres bien
Acheté car le bluetooth d'origine de mon ampli était zéro à plus de 4 metres de distance...
Celui tiens bien le son à 10 mètres (sans mur évidemment, sinon ça coupe).
Ne fonctionne toujours pas bien avec le bluetooth de mon ordinateur (précision : BT reconnu mais liaison instable) ... mais ca, c'est parce que le BT du pc est vraiment pourrie...
Fonctionne niquel avec android ou iphone (anciennes version ou récente... et plus le BT source est récent meilleur est le son)
Son qualité très satisfaisante. Comparable CD. Légèrement mieux qu'un autre émetteur BT testé d'une autre marque et de prix équivalent.
Point d'amélioration à prévoir : si un appareil est connecté dessus, il faut cliquer sur un bouton de l'émetteur BT pour connecter le nouvel appareil. Ca aurait été bien une connexion "à la volée" depuis l'appareil source.
Bon, pas très gênant ...
J'ai priviligié cet outil à du wifi car fonctionne sans réseau internet, aussi car puce semble plus performante que solutions mélengeant BT/wifi (à prix équivalent), et enfin car à l'oreille la qualité est très bonne.
5 étoiles.
EXCELLENT
Câblé en sortie casque avec un câble mini jack vers rca Viablue sur ampli . Connecté en LDAC avec un smartphone . Son excellent avec beaucoup de détails , rivalise sans problème avec le cd voir le dépasse , mérite une connexion de qualité pour profiter de ce support . Recommandé chaudement .
The 1Mii B03Pro+, evolution of the B03Pro, is like its big brother a particularly versatile and powerful Bluetooth receiver and transmitter, always...
