AVANTREE Saturn DB aptX Pack transmitter & Receiver 2 in 1
Reference : 10854
89,00 €tax incl.
74,17 € tax excl.
The Avantree Saturn DB pack makes it possible to transform any analog source, CD player, radio, TV (with RCA output or stereo jack) into a wireless device to receive (amplifier, headphone) via its Bluetooth transmitter and receiver, .
Thanks to the receiver you can enjoy on your helmet, your old Hifi chain of comfort of wireless Bluetooth in quality APTX on a range of 10m. all you need to do is press the center button to pair each Avantree Saturn module.
The Avantree Saturn DB transmitter and receiver have a battery life of 10 hours (manufacturer data).
If you have an AD2P Bluetooth enabled device, the direct connection allows a playback quality very close to the CD-Audio with a low compression ratio.
Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly. When files natively in MP3 or AAC (with a rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
Technical specifications:
  • Bluetooth supported: APT-X, AD2P and AVRCP.
  • Audio Codecs: Bluetooth Apt-X.
  • Scope: 10m class II.
  • Battery of polymer type of 270mAh.
Connections of Avantree Saturn dB:
  • Audio Output / Input: on 3.5mm stereo jack.
  • Rechargeable on USB port.
Supplied accessories:
  • 2 3.5mm jack to 3.5mm male jack + 2 3.5mm jack to RCA stereo.
  • 2 USB cable for charging.
Dimensions and weight:
  • 50 x 35 x 15mm.
  • Weight: 49g per module.
Packaging dimensions:
  • 118 x 168 x 39mm.
