The Avantree Saturn DB pack makes it possible to transform any analog source, CD player, radio, TV (with RCA output or stereo jack) into a wireless device to receive (amplifier, headphone) via its Bluetooth transmitter and receiver, .
Thanks to the receiver you can enjoy on your helmet, your old Hifi chain of comfort of wireless Bluetooth in quality APTX on a range of 10m. all you need to do is press the center button to pair each Avantree Saturn module.
The Avantree Saturn DB transmitter and receiver have a battery life of 10 hours (manufacturer data).
If you have an AD2P Bluetooth enabled device, the direct connection allows a playback quality very close to the CD-Audio with a low compression ratio.
Thus, FLAC, Apple Lossless or PCM audio files are rendered almost perfectly. When files natively in MP3 or AAC (with a rate less than 350Kbits / sec), they are transmitted without decoding and without any degradation.
Technical specifications:
Connections of Avantree Saturn dB:
Supplied accessories:
Dimensions and weight:
Packaging dimensions:
