BERRYBAK BEA1 Bluetooth 5.3 Receiver LDAC Apt-X HD DAC ESS9018K2M 24bit 96kHz
This Bluetooth 5.3 BEA1 receiver from BerryBak is a small, compact device, but no less powerful, since it incorporates components recognized on the audio market. This Bluetooth receiver is equipped with a Qualcomm QCC5171 Bluetooth 5.3 receiver chip, enabling it to support high-resolution codecs such as SBC, AAC, aptX, aptX Adaptive, aptX LL, aptX HD and LDAC.
4.9 / 5
Reference : 18805
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 06-05-2025.
BERRYBAK BEA1 Bluetooth 5.3 Receiver LDAC Apt-X HD DAC ES9018K2M 24bit 96kHz
BERRYBAK BEA1 picture
This Bluetooth 5.3 receiver BEA1 from BerryBak (Wondom) is a small, compact device, but no less powerful, since it incorporates components recognized on the audio market. This Bluetooth receiver is equipped with a Qualcomm QCC5171 Bluetooth 5.3 receiver chip, enabling it to support high-resolution codecs such as SBC, AAC, aptX, aptX Adaptive, aptX LL, aptX HD and LDAC. The BEA1 also incorporates an ES9018K2M DAC chip and a WM8804 SPDIF interface chip for optimal signal processing before the signal is routed to the many available outputs: stereo RCA output, coaxial SPDIF output and Toslink optical output. This receiver's Bluetooth input is also complemented by a USB-C (DATA+POWER) port compatible with the UAC 2.0 protocol, enabling you to enjoy an audio source such as your computer via USB connection.
BerryBak BEA1 interior picture
BERRYBAK BEA1 : Bluetooth 5.3
The Berrybak BEA1 incorporates a latest-generation chip from Qualcomm QCC5171. As mentioned above, the module supports the high-fidelity wireless transmission codecs SBC, AAC, aptX, aptX Adaptative, aptX LL, aptX HD and LDAC, with an unobstructed range of up to 50m. This Bluetooth receiver module promises extremely reliable and stable wireless transmission, with a sampling rate of up to 24bit 96kHz and a maximum transmission speed of 990kpbs in LDAC.
Photo of the BERRYBAK BEA1 Bluetooth QCC5171 chip
Photo of BERRYBAK BEA1 USB connector
BERRYBAK BEA1: USB-C DATA port + POWER SUPPLY
In addition to its Bluetooth input, the BEA1 features a DATA-compatible USB-C power port in UAC 2.0 protocol. This means that, as well as powering the module, you may be able to transmit a PCM audio stream up to 24bit 96kHz via this USB-C port using your computer, for example.
BERRYBAK BEA1 : DAC ES9018K2M
The DAC ES9018K2M chip in the BerryBak BEA1 Bluetooth receiver module enables signal processing to the analog RCA outputs. This DAC chip delivers high-quality sound reproduction with low distortion, a wide soundstage and high dynamic range. In short, audiophile sound reproduction with precise, detailed sound.
Photo of BERRYBAK BEA1 DAC ES9018K2M chip
BERRYBAK BEA1: a complete interface
Photo of BERRYBAK BEA1 application examples
 BERRYBAK BEA1 dimensions
Product typeBluetooth receiver
Bluetooth chipQCC5171
DAC chipES9018K2M
SPDIF interface WM8804
InputsBluetooth
1x USB-C (Power supply + DATA)
Outputs1x RCA stereo output
1x SPDIF coaxial output
1x Toslink optical output
Bluetooth versionBluetooth 5.3
Supported Bluetooth codecsSBC, AAC, aptX, aptX Adaptative, aptX LL, aptX HD and LDAC
Bluetooth range50m (without obstacle)
Supported sample ratesPCM 24bit 96kHz
Alimentation5V 0.5A DC (via USB-C power + DATA port) (power supply sold separately)
Dimensions64 x 95.4 x 26mm
Weight191g
Package1x BerryBak BEA1 Bluetooth Receiver
2x Bluetooth antenna (one short + one long)
1x Toslink optical cable
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsaptX Adaptive
8 reviews
BERRYBAK BEA 1 R2CEPTEUR BLUETOOTH
Excellent rapport qualité prix. Facile à installer , facile à mettre en route!
This review has been posted for BERRYBAK BEA1 Bluetooth 5.3 Receiver LDAC Apt-X HD DAC ES9018K2M 24bit 96kHz
Top génial
Toute la famille peut streamer sa musique. Son vraiment au top, j'adore!!!
DAC BEA1
Ottimo prodotto, costruito bene, molto utili e rare le uscite digitali, per un prodotto di questo livello di prezzo. Spedizione veloce e ottimo imballo. Venditore consigliato.
Super
Je possède déjà un récepteur Fosi et il y a vraiment du bruit problématique, même sans appareil connecté.
Avec ce produit ci, aucun problème, le son est vraiment très clean et la connexion est rapide, le BT 5.3 c'est super, bref très content de mon achat. Je n'utilise que les sorties RCA (vers mon ampli Denon)
Incompatible sur ampli DENON PMA 520
Produit de bonne facture mais incompatible avec mon vieil ampli Denon PMA 520, le volume de sortie RCA du récepteurs est trop faible pour une écoute correcte. Bien dommage
This Bluetooth 5.3 BEA1 receiver from BerryBak is a small, compact device, but no less powerful, since it incorporates components recognized on the...
