Excellent rapport qualité prix. Facile à installer , facile à mettre en route!
This Bluetooth 5.3 receiver BEA1 from BerryBak (Wondom) is a small, compact device, but no less powerful, since it incorporates components recognized on the audio market. This Bluetooth receiver is equipped with a Qualcomm QCC5171 Bluetooth 5.3 receiver chip, enabling it to support high-resolution codecs such as SBC, AAC, aptX, aptX Adaptive, aptX LL, aptX HD and LDAC. The BEA1 also incorporates an ES9018K2M DAC chip and a WM8804 SPDIF interface chip for optimal signal processing before the signal is routed to the many available outputs: stereo RCA output, coaxial SPDIF output and Toslink optical output. This receiver's Bluetooth input is also complemented by a USB-C (DATA+POWER) port compatible with the UAC 2.0 protocol, enabling you to enjoy an audio source such as your computer via USB connection.
The Berrybak BEA1 incorporates a latest-generation chip from Qualcomm QCC5171. As mentioned above, the module supports the high-fidelity wireless transmission codecs SBC, AAC, aptX, aptX Adaptative, aptX LL, aptX HD and LDAC, with an unobstructed range of up to 50m. This Bluetooth receiver module promises extremely reliable and stable wireless transmission, with a sampling rate of up to 24bit 96kHz and a maximum transmission speed of 990kpbs in LDAC.
In addition to its Bluetooth input, the BEA1 features a DATA-compatible USB-C power port in UAC 2.0 protocol. This means that, as well as powering the module, you may be able to transmit a PCM audio stream up to 24bit 96kHz via this USB-C port using your computer, for example.
The DAC ES9018K2M chip in the BerryBak BEA1 Bluetooth receiver module enables signal processing to the analog RCA outputs. This DAC chip delivers high-quality sound reproduction with low distortion, a wide soundstage and high dynamic range. In short, audiophile sound reproduction with precise, detailed sound.
Product type | Bluetooth receiver |
Bluetooth chip | QCC5171 |
DAC chip | ES9018K2M |
SPDIF interface | WM8804 |
Inputs | Bluetooth 1x USB-C (Power supply + DATA) |
Outputs | 1x RCA stereo output 1x SPDIF coaxial output 1x Toslink optical output |
Bluetooth version | Bluetooth 5.3 |
Supported Bluetooth codecs | SBC, AAC, aptX, aptX Adaptative, aptX LL, aptX HD and LDAC |
Bluetooth range | 50m (without obstacle) |
Supported sample rates | PCM 24bit 96kHz |
Alimentation | 5V 0.5A DC (via USB-C power + DATA port) (power supply sold separately) |
Dimensions | 64 x 95.4 x 26mm |
Weight | 191g |
Color | Black |
Package | 1x BerryBak BEA1 Bluetooth Receiver 2x Bluetooth antenna (one short + one long) 1x Toslink optical cable |
Input | USB |
Input | Bluetooth |
Output | Optical Toslink |
Output | Coaxial SPDIF |
Output | RCA |
DAC / ADC Chip | ES9018K2M |
Color | Black |
Transmission / Reception protocol | Bluetooth |
Supported Bluetooth codecs | aptX LL |
Supported Bluetooth codecs | LDAC |
Supported Bluetooth codecs | AAC |
Supported Bluetooth codecs | aptX HD |
Supported Bluetooth codecs | aptX Adaptive |
Supported Bluetooth codecs | SBC |
Supported Bluetooth codecs | aptX |
Average votes 4.9 / 5 8 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Bruno C.
Vincent C.
Fabrizio P.
Cyril C.
Franck M.
