Bluetooth 5.0 Receiver Transmitter Micro SD RCA Jack 3.5mm
This small Bluetooth 5.0 receiver and transmitter offered at a low price will allow you to broadcast your music wirelessly to a classic audio system or a headphone for example.
1.0 / 5
Reference : 17228
16,90 €tax incl.
14,08 € tax excl.
Bluetooth 5.0 Receiver / Transmitter
Récepteur / Émetteur Bluetooth 5.0
This small Bluetooth 5.0 receiver and transmitter offered at a low price will allow you to broadcast your music wirelessly to a classic audio system or a headphone for example. In addition to the bi-directional Bluetooth, the device provides a Micro SD slot as well as a stereo RCA and Jack 3.5mm input/output. It also has a display showing pairing information for easy and convenient use.
Use of the buttons :
- Volume control: Long press on "Previous music" or "Next music"
- Music selection: Single press on "Previous music" or "Next music"
- Play / Pause: Single press on "M"
- Switching from receiver to transmitter mode and vice versa: Long press on "Previous music" and "Next music" at the same time
- Search again in transmitter mode: Double press "M".
The receiver is identified by the name "C39S".
Product typeBluetooth receiver and transmitter
InputsBluetooth 5.0
1* Stereo RCA
1* Jack 3.5mm
1* Slot Micro SD
OutputsBluetooth 5.0
1* Stereo RCA
1* Jack 3.5mm
Supply voltage5VDC 1A
Dimensions (L*P*H)69*69*23.5mm
Package1* Bluetooth receiver/transmitter
1* RCA to Jack 3.5mm cable
1* Jack 3.5mm cable
1* USB-A to USB-C cable
InputJack 3.5mm
InputMicro SD
OutputBluetooth
OutputJack 3.5mm
DAC / ADC ChipNC
Supported Bluetooth codecsN/A
Qualité audio médiocre
Bonjour. Bon, dur de rédiger un avis négatif tant j'ai toujours apprécié les produits d'audiophonics.
J'ai déjà acheté ce type de produit en chine et chez aldi... Chacun à très bas prix. Donc je pense pouvoir comparer.
La qualité audio de celui-ci est vraiment très mauvaise. Honnêtement passez votre chemin, c'est le meilleur conseil que je puisse vous donner.
This review has been posted for Bluetooth 5.0 Receiver Transmitter Micro SD RCA Jack 3.5mm
This small Bluetooth 5.0 receiver and transmitter offered at a low price will allow you to broadcast your music wirelessly to a classic audio...
