FIIO BR13 Bluetooth Receiver
The FiiO BR13 is a Bluetooth receiver equipped with a high-performance DAC.
KEY FEATURES:
  • Bluetooth 5.1 QCC5125 receiver chip
  • SBC, AAC, aptX, aptX adaptative, aptX LL, aptx HD, LDAC
  • DAC ES 9018K2M
  • 24Bit 96kHz
  • TPA1882
  • EQ and presets via control application
4.0 / 5
Reference : 18506
69,00 €tax incl.
57,50 € tax excl.
Shipping date: 26-08-2025.
FIIO BR13 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz
This BR13 Bluetooth receiver from FiiO is equipped with an ES9018K2M DAC chip, a QCC5125 Bluetooth version 5.1 receiver chip and a TPA1882 amplifier chip. Versatile and high-performance, it boasts a wide range of connectors, including Toslink optical, coaxial SPDIF and USB-C inputs, as well as two outputs: a stereo RCA line output and a Toslink optical output. This makes it compatible with a large number of Hi-Fi devices for easy integration into your sound system, chained directly to a DAC, power amplifier or active speakers, for example. It accepts 24-bit 96kHz resolution streams via its inputs, and is capable of reproducing a 2Vrms signal level via its RCA output.
FIIO BR13 : Bluetooth 5.1 QCC5125 receiver chip
The Qualcomm QCC5125 Bluetooth receiver chip enables FiiO's BR13 to support high-resolution Bluetooth codecs; SBC, AAC, aptX, adaptive aptX, aptX LL, aptx HD, LDAC. It supports multiple connections to up to 2 simultaneous devices for easy source switching. Low Latency mode (aptX LL) lets you use the BR13 to watch movies or play video games while avoiding latency effects.
FIIO BR13 : Presets and EQ for a customizable listening experience
Thanks to its control application, the BR13 gives you access to 7 presets and 2 types of EQ settings with 10 adjustable frequency bands. This feature allows you to customize your listening experience according to your tastes and audio source.
FIIO BR13 : Upsampling technology
FiiO's proprietary technology enables the BR13 to upsample low-resolution streams up to 24Bit 96kHz via all its inputs, for quality sound reproduction.
FIIO BR13 : A high-performance chipset
The BR13 integrates high-quality components: a QCC5125 Bluetooth receiver chip, an ES9018K2M DAC chip and a TPA1882 amplifier chip. The combination of these three components guarantees quality sound reproduction. The ES9018K2M DAC chip is a 32-bit stereo chip from ESS Technologie specially designed for audiophile applications. In addition, the TPA1882 operational amplifier chip guarantees low distortion and noise levels. In terms of performance, FiiO's BR13 boasts an SNR > 112dB as well as a THD+N < 0.0008% on its non-Bluetooth inputs and a THD+N < 0.0018% in Bluetooth LDAC.
FIIO BR13: Many possible configurations
Bluetooth input
USB input
Optical/SPDIF input
Optical/SPDIF input
Overview of the FiiO BR13 Bluetooth receiver
1RCA stereo line output
2Toslink optical input
3SPDIF Coaxial input/output
4Toslink optical output
5USB-C input
6Bluetooth antenna
Product typeBluetooth Receiver
DAC ChipES9018K2M
Amplification chipTPA1882
Bluetooth ChipQCC5125
Inputs1x USB-C input
1x Optical Toslink input
1x Coaxial SPDIF input/output
Bluetooth
Outputs1x Optical Toslink
1x SPDIF Coaxial input/output
1x RCA stereo
Supported Bluetooth codecsAAC / SBC / aptX / aptX LL / aptX Adaptive / aptX HD / LDAC
Multi-sources Bluetooth
Supported sample ratesLocal: 32Bits 96kHz
Coaxial input: 32Bits 192kHz
Toslink input: 24Bits 96kHz
Coaxial output: 24Bits 96kHz (upsampling x2)
Toslink output: 24Bits 96kHz (upsampling x2)
ScreenLCD
LDAC BLUETOOTH RECEPTION AND RCA LINE OUTPUT MEASUREMENTS
THD+N< 0.002% (1kHz / -0dB @ 10KΩ)
Crosstalk≥ 98dB (1kHz / -0dB @ 10KΩ)
Frequency response20Hz-20KHz
SNR≥ 113dB (A-weighted)
Noise floor<5uV (A-weighted)
RCA line output level2Vrms
RCA LINE OUTPUT MEASUREMENTS (USB DAC INPUT/OPTICAL DECODING)
THD+N< 0.0006% (1kHz / -0dB @ 10KΩ)
Crosstalk≥ 108dB
SNR≥ 114dB (A-weighted)
RCA LINE OUTPUT MEASUREMENTS (SPDIF INPUT)
Crosstalk≥ 109dB
Frequency response20-20KHz : damping < 1.9dB
20Hz-50KHz : damping < 1.2dB
RCA line output level2vrms
Power supply voltageUSB 5V 1A
Dimensions98 x 96 x 26.5mm
Net weight135g
Package1x FiiO BR13 Bluetooth receiver
1x USB-A to USB-C cable (Data)
OutputOptical Toslink
OutputCoaxial SPDIF
DAC / ADC ChipES9018K2M
Supported Bluetooth codecsaptX
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsaptX Adaptive
Supported Bluetooth codecsSBC
4 reviews
Excellent au delà de mes attentes
J'ai choisi ce produit pour améliorer mon Bluetooth actuel, avec les codecs LDAC et AAC pour Androïd et Apple, et aussi parce qu'il comporte un volume donc je peux directement attaquer mes deux amplis en mono.
Tout est vraiment mieux, la clarté du son, les basses, et la spacialisation a fait un bond en avant.
J'avais un correct Real Câble et j'ai clairement changé de catégorie.
Je vous le conseille, avec en plus ses entrées digitales ...
This review has been posted for FIIO BR13 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz
Fiio BR13
En soi concernant le BT il fait son job. En revanche l equalizer paramétrique bug puisqu on ne peut pas le sauvegarder ( bug Fiio connu et non corrigé honteux !
Parfait
fait le job pour moderniser une chaine HiFi qui n'avait pas d'entrée Bluetooth ou USB.
rappel : la qualité de la transmission dépend de la source (mp3, CD, qualité studio, ...)
entrée Bluetooth :
il faut une alimentation externe (prise USB)
appairage sans difficulté avec le smartphone
appairage plus compliqué avec le PC (w10) : il m'a fallu aller dans la gestion des services windows (prise en charge Bluetooth) et basculer la sortie audio du PC de "haut-parleurs" vers "audio FiiO BR13" pour transmettre le son vers la chaine.
entrée USB :
la source (PC) fournit à la fois les données et l'alimentation (USB Type-A)
Parfait pour le prix
Utilisé pour streamer des radios de mon smartphone(TuneIn) sur mon système HiFi, parfait pour le prix.
The FiiO BR13 is a Bluetooth receiver equipped with a high-performance DAC. KEY FEATURES: Bluetooth 5.1 QCC5125 receiver chip SBC,...
