FIIO BTR11 Portable Bluetooth Receiver Headphone Amplifier
The FiiO BTR11 is a portable Bluetooth headphone amplifier receiver offering a qualitative wireless music listening experience. Its BES2700 Bluetooth receiver chip and independent headphone amplifier support the high-definition LDAC codec (24bit/96kHz), while its 3.5mm jack headphone output delivers substantial power output.
Reference : 20235
20,90 €tax incl.
17,42 € tax excl.
Shipping date: 02-06-2026.
FIIO BTR11 Portable Bluetooth Receiver Headphone Amplifier Bluetooth 5.3 LDAC
FiiO BTR11 picture
The FiiO BTR11 is a portable Bluetooth receiver headphone amplifier offering a qualitative wireless music listening experience. Its BES2700 Bluetooth receiver chip and independent headphone amplifier support the high-definition LDAC codec (24bit/96kHz), while its 3.5mm jack headphone output delivers substantial power output. It can deliver up to 2x 45mW @ 16 ohm and 2x 30mW @ 32 ohm. The BTR11 recharges via USB-C for up to 15h autonomy, making it perfect for everyday use or travel, for example.
FiiO BTR11 highlights
FiiO BTR11: high-definition Bluetooth
The BES2700 Bluetooth receiver chip supports LDAC (24bit/96Khz) for the most reliable, stable and high-quality wireless transmission. It also enables two devices to be paired simultaneously, so you can quickly switch from one activity to another. An indicator LED also helps determine Bluetooth operation:
  • Red light: battery low
  • Blue light: devices connected
  • Flash every 5 seconds: SBC
  • Two rapid flashes: AAC
  • Three rapid flashes: LDAC
FiiO BTR11 Bluetooth function
FiiO BTR11 headphone amplifier
FiiO BTR11: independent headphone amplifier
The FiiO BTR11 features a HT97220 headphone amplifier with an output power of up to 2x 45mW @ 16 ohm, capable of driving most low-impedance headphones and IEMs on the market and transforming them into wireless headphones.
FiiO BTR11 circuitry
FiiO BTR11: An efficient battery
The FiiO BT11's battery is capable of providing up to 15h of autonomy in the best conditions. It can be recharged via USB-C in just over an hour.
FiiO BTR11 battery
FiiO BTR11 added extras
Fast reconnection
Fast reconnection
If it's disconnected, simply press the dedicated button for a quick reconnection.
Noise reduction for calls
A high-sensitivity microphone provides noise reduction during phone calls for clearer sound.
Turning your active speakers into Bluetooth speakers
Turn your active speakers into Bluetooth speakers
Not only can the BTR11 be used with IEMs, it can also transform your active speakers into Bluetooth speakers.
FiiO BTR11: a compact, practical form factor
The BTR11's minimal size and weight make it easy to carry. In addition, it features a clip for attaching it to any item of clothing, so you're always free to move around.
The FiiO BTR11 form factor
Product typeBluetooth receiver
Headphone amplifier
Bluetooth chipBES2700
Headphone amplifierHT97220
InputBluetooth 5.3
Output3.5mm headphone output
Supported Bluetooth codecsAAC, SBC, LDAC
Output power2x 45mW @ 16ohm (THD+N=1%)
2x 30mW @ 16ohm (THD+N=1%)
2x 3mW @ 300ohm (THD+N=1%)
Recommanded impedance8-100 ohm
THD+N< 0.008% (1kHz/-3dB@32Ω)
Frequency response20Hz-20kHz : damping < 0.5dB
20Hz-45kHz : damping < 2.3dB
Output impedance≤ 0.5Ω
Channel separation≥ 76dB
SNR≥ 101dB(A-weighted)
Noise floor≤ 8uV (A-weighted)
Volume controlPhysical buttons
LED indicator
MicrophoneBuilt-in omnidirectional microphone supports Bluetooth phone calls
Charging5V 1A via USB-C
Battery capacity120mAh (lithium polymer)
Battery autonomyUp to 15h (AAC) / up to 8.5h (LDAC)
Charging time< 1.5h
Dimensions55 x 19 x 14.6mm (with clip)
Weight13g
Package1x FiiO BTR11
1x USB-A to USB-C cable
OutputJack 3.5mm
DAC / ADC ChipBES2700
Supported Bluetooth codecsSBC
Supported Bluetooth codecsLDAC
The FiiO BTR11 is a portable Bluetooth headphone amplifier receiver offering a qualitative wireless music listening experience. Its BES2700...
