fait le Job, parfaite connexion stable et de bonne qualité audio donc pourquoi dépenser plus, merci Audiophonics, envoi rapide et soigné
The FX-Audio upgrades its BL-MUSE-02 to make room for the BL-MUSE-03. Maintains a high level of quality, whether in the design or component selection, while offering new features and improved performance
POINTS CLÉS :
4.2 Bluetooth Receiver NFC & Headphone Amplifier
The FX-Audio upgrades its BL-MUSE-02 to make room for the BL-MUSE-03. This maintains a high level of quality, whether in the design or component selection, while offering new features and improved performance.
The first size change, the supported Bluetooth standard is now 4.1 to 4.2. A more secure, faster and more energy-efficient version of Bluetooth. In this case, the BL-MUSE-03 achieves higher performance than its predecessor.
The BL-MUSE-03 comes with a full output connector to adapt to individual needs. This includes a Coaxial RCA, a Stereo RCA, and a Toslink Optics. In addition, an antenna ensures the transmission quality and the power supply of the device is via its Micro USB connector (power supply provided).
To ensure excellent Bluetooth transmission quality, the FX-Audio BL-MUSE-03 comes with a Qualcomm BlueCore CSRA64215 4.2 standard chip. It is designed for audio applications and supports A2DP, SBC and AAC technologies.
The DAC AKM AKM AK4452VN is a new-generation DAC with the Velvet Sound Archive, widely used for high-end audio devices. This technology achieves a very high level of detail with very low distortion and noise, while taking advantage of a 32-bit digital filter.
To ensure that the BL-MUSE-03 is a headset amplifier, the BL-MUSE-03 is based on a Maxim MAX9722 amplifier chip. This system integrates a noise cancellation system and ensures a THD of 0.07%, a SNR of 90dB and 200mW power.
Bluetooth | |
Bluetooth Chip | Qualcomm BlueCore CSRA64215 |
Bluetooth Version | 4.2 / AptX |
Modulation method | π / 4 DQPSK, 8DPSK |
Supported Bluetooth Protocols | SBC AAC HFPV 1.6 HSP V1.2 A2DP V1.3 AVRCP V1.6 DIV 1.3 |
Transmission distance | 10m |
Transmission power | Class 1 / Class 2 / Class 3 |
Frequencies | -12.4GHz - 2.480 GHz |
Amplifier / DAC | |
Sensibilité | -92dbm DQPSK Receiver -82dbm 8PSK Receiver |
DAC | AKM AK4452VN |
Headphone amplifier chip | Maxim MAX9722 |
Sample rate | 24bit 48kHz |
Frequency response | 20Hz - 20kHz |
THD | 0.06% |
Headphone Output THD | 0.07% |
SNR | 93dB |
Headphone OutputSNR | 90dB |
Headphone output power | 200mW |
Connectors : Outputs | |
Optical Toslink | 1x |
Coaxial RCA | 1x |
RCA Stereo | 1x |
Jack 6.35mm | 1x |
Power Supply | Micro USB 5V 1A |
Dimensions | 150 x 98 x 33mm |
Weight | 292g |
Color | Black |
Package | 1x FX-Audio BL-MUSE-03 1x Power Supply 1x Antena |
Average votes 4.8 / 5 12 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
Pascal M.
Pierre B.
renaud c.
gilles b.
Jean-Pierre G.
