SMSL B100 Bluetooth Receiver
SMSL's B100 is a Bluetooth 5.1 receiver with versatile outputs and a rigorous, high-quality design. It is based on an AK4493S DAC chip to deliver the most faithful and crystal-clear sound reproduction possible, ensuring a signal-to-noise ratio of 128dB and a harmonic distortion rate of 0.0002%. All of this is housed in a magnificent CNC-machined aluminium case to ensure that the aesthetics match the technical performance of the device.
By buying this product you get 22 loyalty points
Reference : 20072
229,00 €tax incl.
190,83 € tax excl.
Shipping date: 14-04-2026.
SMSL B100 Bluetooth 5.1 Receiver AK4493S aptX HD LDAC UAT
SMSL B100 : Front view
SMSL B100: Key features
SMSL B100: AK4493S DAC chip
SMSL's B100 is based on a latest-generation AK4493S DAC chip, offering low harmonic distortion and a dynamic range of 128dB. This is powered by a low-noise switching mode power supply, reducing interference and guaranteeing stable performance for your audio installation.
SMSL B100 : AK4493S DAC chip
SMSL B100 : Rear panel
SMSL B100: Bluetooth 5.1 connectivity
The B100 uses a 5.1-standard Bluetooth chip, compatible with the LDAC, UAT and AptX HD high-resolution transmission protocols, enabling the signal to be transmitted at up to 24bit 192kHz. On the output side, this device offers excellent versatility with a stereo RCA output, a coaxial output, an optical output and an AES/EBU output.
SMSL B100 : Schéma de présentation
1ON/OFF button
2LED indicator
3RCA line output
4Coaxial output
5Optical Toslink output
6Bluetooth antenna
7AES/EBU output
8Power input
Product typeBluetooth receiver
InputBluetooth 5.1
Outputs1x Stereo RCA
1x Coaxial
1x Optical Toslink
1x AES/EBU
Output level2Vrms
THD+N0.0002% (113dB)
Dynamic range128dB
SNR128dB
Sampling rate44.1 ~ 192 kHz
Bluetooth specificationsUAT: 24bit/192kHz (1200kbps)
LDAC: 24bit/96kHz (990kbps/660kbps/330kbps)
apt-X HD: 24bit/48 kHz_576kbps
aptX: 16bit/48 kHz_352kbps
SBC: 16bit/44.1 kHz_328kbps
AAC: 16bit/44.1 kHz_320kbps
Supply voltage100-240V AC
Power consumptionIn use: <2W
Standby: <0.1W
Dimensions200 x 34 x 175mm
Weight870g
Package1x SMSL B100
1x Power cable
1x Bluetooth antenna
OutputOptical Toslink
OutputCoaxial SPDIF
OutputAES/EBU
DAC / ADC ChipAK4493S
ColorSilver
Supported Bluetooth codecsSBC
Supported Bluetooth codecsaptX
Supported Bluetooth codecsLDAC
Supported Bluetooth codecsAAC
Supported Bluetooth codecsUAT
Download
SMSL's B100 is a Bluetooth 5.1 receiver with versatile outputs and a rigorous, high-quality design. It is based on an AK4493S DAC chip to...
