By buying this product you get 31 loyalty points
Housing 360 x 400 x 210 front face 4 mm Black
HIFI 2000 Housing with dissipators are ideal to build HiFi amplifiers or any kind of high-power device. The massive aluminum / steel frame is very sturdy and long-lasting. The HIFI 2000 dissipators series offer different sizes regarding electronic casing. While being versatile enough to be used in a variety of projects, it remains easy to mount and to use.
In addition to large dissipators with vertical wings (40mm), this housing has many opening on its top-plate in order to maximise heat circulation. The materials used in the building process are also very efficient at lowering termal stress.
| Spécifications | |||
| Dimensions | Height | Width | Depth |
| Internal | 210 | 360 | 400 |
| External | 212 | 440 | 405 |
| Specifications | |
| Type | Mounting housing |
| Front cover | Aluminum 4mm thick |
| Back cover | Anti-scratch Steel 1mm thick |
| Side covers | 4 dissipators 40x200mm Anodized aluminum |
| Top & bottom covers | Anti-scratch Steel 1mm thick |
| Weight | 8.4 kg |
