Section (mm²)
0 mm - 15 mm
Diameter (mm)
Conductors material (Cable)
Conductors Plating (Cable)
Number of conductors
Insulation material
Ground / Shielding
Shielding
Walter V.
Great product!
Joli mais non..
NAEL C.
Marvelous !
Speaker Cables
Find here all our cables for speakers and loudspeakers, sold by the meter, cut, allowing the design of your own finished cables.
