RAMM AUDIO AMADEUS 5 MK2 Speaker Cable OCC Copper 6x1.5mm² Ø16mm
4.8 / 5
Reference : 12202
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 02-06-2026.
MMAR Amadeus 5 Mk2
ramm-audio-amadeus-5-mk2-cable-hp-cuivre
Designed according to extremely strict specifications, the Amadeus 5 Mk2 cable is dedicated to wiring (& bi-wiring) loudspeakers and to power cables.
This speaker cable / power offers superior performance thanks to the use of materials and manufacturing methods that are rare in this price range.
The conductors are six core pure copper OCC and its insulating structure (Air Geometry Design) uses air with a pattern designed by the mark itself.
Structure%20c%C3%A2ble%20AMADEUS%205%20M
The connectors are arranged so that the wiring of your devices according can be "tuned" according to their strengths and their weaknesses. One can dedicate 2x2 conductors to the positive and 2x1 conductor to the negative to obtain a rich and balanced sound stage in a bi-wiring context. Conversely, less symmetrical arrangements may also be made for filter / crossover.
In addition to the six main strands of 16AWG there is a seventhdriver designed to connect the mass and thus avoid most noise.
Definitely audiophile, Amadeus cable 5 Mk2 offers pure performance through high quality multiple conductors and a protective screen shield Aluminum / PP / PVC.
All conditions are met for optimal resistance to interference with minimal distortion.
Bi-wiring amplifier
Amadeus 5 wiring diagram
Wiring for AC outlet
Amadeus 5 wiring diagram sector
TypeCable sold by the meter
ConductorsPure copper OCC 11AWG (4.17mm²)
Cores6 cores made from 6x7 conductors
InsulatingDesigned by Ramm / air geometrical structure and polypropylene
Diameter per conductorApprox. 2mm
Total Diamtètre16mm
Common useSpeaker câble / Double speaker cables / power cable
PVC bodyBraided Nylon & PVC Body Blue
Diameter (mm)16.0
Length (m)Sold by length
Number of conductors6
Insulation materialPE
ShieldingYes
Section (mm²)1.5
Ground / ShieldingYes
35 reviews
Comme d’habitude, un super cable pour toutes les applications. A acheter sans risque d’être déçu.
This review has been posted for RAMM AUDIO AMADEUS 5 MK2 Speaker Cable OCC Copper 6x1.5mm² Ø16mm
Organique
Merci à Audiophonics pour le bonus.
Monté en cable secteur pour mon subwoofer et ma barrette .
Au vue de la description technique, je m’attendais à un son étagé, de la précision, de la transparence et une large bande passante , c’est le cas mais la surprise, c’est son côté organique, fluide, son liant.
Au prix où est proposé ce cable, il faut avouer que la prestation est haut de gamme.
Neutralité
Grace aux conseils de David j'ai pu réaliser mes câbles HP après de nombreuses hésitations , j'ai enfin trouvé le câble le plus neutre pour mon système ( ampli Atoll Am200, enceintes ELAC FS 408.2 ) ce câble: le RAMM Audio Amadeus 5 Mk2, transparence dans les graves, les médium ainsi que dans les aigus.
Merci encore pour votre gentillesse et votre patience.
Philippe Ropert
Incroyable
Acheté à la base pour des câbles CS qui donnent entière satisfaction, je le'ai utilisé en câble H.P et quelle surprise. Câble très équilibré qui apporte beaucoup de douceur aux aigus sans les dénaturer, tout est en place place avec et associé à de bons connecteurs c'est un pur plaisir.
J'ai utilisé les Furutech FT 212 qui passe juste si vous habillé les terminaisons avec de la gaine, mais ça passe. Le hic, c'est la préparation, il faut beaucoup de patience pour dénuder les brins de cuivre, 4 par conducteur soit 48 par câble, 3 sont déjà à nu.
Bref un très bon câble bien conçu sans se ruiner. Je conseille vivement, ils ont remplacé mes DUELUND.
Excellent
Avec ce câble, j’ai à la fois réalisé des cables d’enceintes et des cables secteur. Le résultat est à la hauteur de ce que j’attendais. J’ai essayé sur plusieurs types d’enceintes. Ce câble amène plus de douceur, de neutralité, de définition et à la fois plus de dynamisme.
Soyez bien équipé des bons outils. La pince à dénuder est obligatoire, Une petite pince qui serre, mais sans couper vous permettra de dénuder les petites gaines PE.
Si vous voulez relier votre câble à la carcasse de votre ampli, il faudra couper une première fois et recouper une seconde fois les cables de manière à ce que le fil de drain soit plus long.
Je note cinq étoiles ce câble, mais je note uniquement 2 étoiles le service commercial, qui n’a pas été à l’écoute de ma demande. Ils m’ont automatiquement orienté vers des cables d’une autre marque (Mogami, elecaudio) Qui soi-disant ont un meilleur rapport qualité prix. Je connais ces cables et il n’arrivent pas au niveau des ramm audio. À croire que les commerciaux de Audiophonics se basent uniquement sur les avis et le nombre de ventes… D’autre part, même pour une commande de 1000 € pour 14 m de câble, ils sont inflexibles sur les prix. Dommage que la démarche commerciale ne soit pas de la partie.
