FURUTECH FP-S55N LIMITED EDITION Power Cable OFC Copper Silver Gold Nano Liquid Alpha Treatment 5.26mm² Ø18mm
This premium limited edition Furutech FP-S55N power cable has been designed with the utmost care and the best components and techniques to allow your audio system to deliver its full potential and your music to express itself in the most beautiful way. As the AC power supply is the starting point of any audio system, the power cable is a decisive element in the quality of playback.
4.6 / 5
By buying this product you get 42 loyalty points
Reference : 13671
219,00 €tax incl.
182,50 € tax excl.
Shipping date: 12-08-2025.
Câble vendu au mètre
Furutech FP-S55N Limited Edition
Câble Secteur Cuivre OFC Nano Liquid Argent Or Traitement Alpha 5.26mm² Ø18mm
Furutech FP-S55N Limited Edition Câble Secteur Cuivre OFC Nano Liquide Argent Or Traitement Alpha 5.26mm² Ø18mm
The Furutech Alpha Nano-Ag-Au driver is one of the brand's best drivers. The new technology used in the production process of this high-performance cable combines Alpha processed OFC Copper conductors (α) with Furutech's Nano Liquid, further improving signal transmission capabilities.
The molecules of this Nano Liquid are so tiny (8nm in diameter = 8/1000000mm) that they cover the surface of the Alpha-OFC conductors while filling the concave/convex sections resulting from the production process. This increases the electrical conduction surface area. This very precise mixture of micro particles of Silver and Gold, combined with the use of Squalene oil, offers a breathtaking reproduction with extremely low noise, a more than realistic sound image, musical mediums, precise and controlled bass and high dynamics.
Product typePower cable
ConductorOFC Copper with Alpha treatment and Nano Liquid
Conductor diameter3.2mm
Conductor section5.26mm² (10AWG)
InsulationPVC (Brown, light blue, green/yellow)
Insulation diameter5.2mm
Internal sheathPVC (Black)
Internal sheath diameter12.5mm
ShieldingBraided OFC Copper 0.12mm
External sheathPVC (Dark blue)
External sheath diameter18mm
QuantitySold per meter
Diameter (mm)18.0
Length (m)Sold by length
Number of conductors3
Insulation materialPVC
ShieldingYes
Section (mm²)5.26
ConnectorN/A
Ground / ShieldingYes
13 reviews
Avis
Sur un ampli BC ACCOUSTIQUE EX362D avec des Monitor Audio Silver 300 7g que je trouve un haut du spectre présent, ce câble ferait-il l'affaire ?
This review has been posted for FURUTECH FP-S55N LIMITED EDITION Power Cable OFC Copper Silver Gold Nano Liquid Alpha Treatment 5.26mm² Ø18mm
Cable secteur au son rond et chaud
J'ai acheté ce câble secteur pour le monter avec des VIBORG VE & VF 502G, en vue de remplacer un "LC-2 EVO" pour calmer les ardeurs d'un Atoll IN300. À ce jour le câble à 120 h, beaucoup parlent de 500 h et plus de rodage pour qu'il donne sont pleins potentielle.
J'ai obtenu le résultat voulu avoir un son plus chaud et plus rond, un beau bas médium et des basses plus présente sans pour autant perdre sur le reste. À voir dans le temps le résultat final.
Fantastic cable that requires patience
This cable deserves 5 stars because it does something, especially in the midrange, that other cables in the DIY sector cannot, not even the more expensive Furutech DPS 4.1. This cable creates a space, palpability and representation of reality that is unprecedented. You have to hear it to understand what I mean here. In my opinion, many cables focus too much on transparency, which makes the sound too "white". This cable does not do that. He reveals every detail but not with excessive transparency. But be careful. After purchasing this cable, I initially considered it a bad purchase. The high tones lagged behind, causing the cable to sound dull. Give this cable time...a lot of time. I didn't keep track of the hours, but it's not impossible that the cable needed 800 or perhaps more hours to really start sounding. I can no longer imagine without this cable in my installation. However, I also realize that you should not provide your entire installation with these cables. He's too unusual for that. Start with a cable and try to tune the installation to your sound with other cables (DPS 4.1 for example). For transparency freaks: forget this cable. This cable has more of a tube sound.
La classe !!!
Remarquable produit avec une qualité de construction et un niveau de conductivité de très haut niveau. Dès le départ, il se passe quelque chose sur la restitution sonore malgré le fait reconnu que le rodage est très très long sur ce câble. Que cela va être après celui-ci ?? Large bande passante avec une beauté de timbres et une vigueur peu commune sans assécher le message. Bravo Furutech.
Un cran au dessus
Comme de nombreux clients, je me suis constitué quelques câbles furutech, j'en ai gardé 2, le 31 et le 32, les 31 pour mon préampli, l'alimentation de mon streamer et mon dac, c'est un câble que je trouve cohérent. Pour l'ampli et la barrette j'ai choisi le 32 un peu plus présent dans le grave mais un peu moins bon dans le haut médium. Le 55 est nettement plus long à rôder, les premières heures sont une catastrophe (c'est bouché, peu d'aigu, on peut vite regretter son achat) il faut l'accepter. Aujourd hui après une cinquantaine d'heures, le câble s'est ouvert, j'y retrouve les qualités du 32 avec un grave encore mieux défini et lhaut du spectre qui ressemble au 31.
P. S : il fonctionne avec une Schuko fi46 et une IEC Fi48 argent.
This premium limited edition Furutech FP-S55N power cable has been designed with the utmost care and the best components and techniques to allow...
