Connector
Length
0 m - 15 m
Section (mm²)
0 mm - 15 mm
Conductors material (Cable)
Conductors Plating (Cable)
Shielding
Walter V.
Great product!
Joli mais non..
NAEL C.
Marvelous !
Speakers Cables
Find here all our cables allowing the connection of your speakers to your audio system.
