By buying this product you get 66 loyalty points
No featrued products
This high end speaker cable is assembled with Oyaide phosphore bronze banana plugs with silver and rhodium plating, designed on a precision CNC machine extruded on round bars.
The banana twin screw clamping system ensures a strong mechanical hold on the cable.
Oyaide 3000 B speaker cable has a double silver and platinum plating offering high longevity while keeping all its electrical qualities over time. Type 3E plus braiding is designed by Japanese company Sanshu Technology and was first used in medical application for its superior conductivity over conventional coaxial braiding systems.
The ACROSS 3000 B is developed for music lovers looking for a sound of great neutrality over the entire bandwidth, musical, a perfect balance between definition and a warm timbre.
The Cross System Stabyliser system allows the least possible contact between the conductor and the insulation providing increased mechanical stability.
| Specifications | |||
| Type | Speaker cable | ||
| Conductor | Copper 102SSC | ||
| Isolation | High density polyethylene | ||
| Connectors | Oyade Bananas SRBN phosphorus bronze Silver / rhodium plating 2 levels | ||
| Diameter | 9.2 x 18.5 mm | ||
| Conductor resistance | 0.63 Ω / 100 m | ||
| Capacitance | 34pF/m (1 kHz) | ||
| Length | 3m | ||
| Sold by | Pair | ||
| Length (m) | 3.0 |
| Shielding | NC |
| Section (mm²) | N/A |
| Connector | Banana |
| Conductors Plating (Cable) | None |
