VAN DEN HUL THE MAGNUM HYBRID Speaker Cable
This Van Den Hul The Magnum Hybrid cable features 2x483 strands of grain-oriented, deoxygenated OFC copper. Each strand is then plated with pure silver.
Reference : 18833
52,90 €tax incl.
44,08 € tax excl.
Shipping date: 20-05-2025.
Câble vendu au mètre
VAN DEN HUL THE MAGNUM HYBRID Speaker Cable Silver Plated OFC Copper 2x8.54mm²
VAN DEN HUL THE MAGNUM HYBRID Câble Haut-Parleur Cuivre OFC Plaqué Argent 2x8.54mm²
This Van Den Hul The Magnum Hybrid speaker cable features 2x483 strands of OFC copper. Each strand is then plated with pure silver. For each of the 2 conductors, a saturated layer of LSC (Linear Structured Carbon) is placed between the insulation and the group of metal strands, to reduce interface micro-discharges between conductor and insulation. As mentioned earlier, each conductor is made up of 483 strands, bringing the total cross-section of each conductor to 8.54mm², or 8 AWG. The capacitance between the two conductors is 27 pF/m. The DC resistance of each conductor is 0.21 Ohms/100m. The cable sheath is made of red Hulliflex® 5, a high-performance, robust, halogen-free insulating material offering excellent mechanical protection and high chemical stability.
Product typeSpeaker cable
Total section2 x 8.54mm2.
MaterialOFC Copper / Silver
Resistance0.21 Ohm/100m
Capacity27 pF/m
InsulationHULLIFLEX red sheath
Total lenght28mm
Total thickness7,2mm
QuantitySold by meter
Diameter (mm)7.2
Number of conductors2
Insulation materialOther
ShieldingNo
Section (mm²)8.54
Ground / ShieldingNo
SUPERB, not bright
Using with PrimaLuna Evo 300 tube integrated amp, Amphion Argon 3S speakers. This cable replaced Canare 4S11 cable which I was previously using. It was easy to terminate and route. Sound is amazing. More bass, more detail, and no brightness! It also has a very old school vibe. I've spent days researching cable before landing on this one, glad I did.
You can buy 16mm nylon sleeving of whatever colour should you want to change the look. Don't let the look be the influencing factor!
This review has been posted for VAN DEN HUL THE MAGNUM HYBRID Speaker Cable Silver Plated OFC Copper 2x8.54mm²
This  Van Den Hul The Magnum Hybrid  cable features 2x483 strands of grain-oriented, deoxygenated  OFC copper....
